Old 03-13-2005, 02:11 PM
Srs3065 Srs3065 is offline
Send a message via Yahoo to Srs3065
97 Lumina fast idle, low acceleration
I have a 97 Lumina just had the intake manifold done by a buddy, after he finally got the spark plug wires right, it seemed ok. Then it started idling super high. Checked the throttle cables all seemed ok. Took it on the freeway and noticed very bad acceleration, though the car would stay at speed without my foot on the gas. Could this be egr sensor or oxg. sensor? Tried to check the vacume lines as best I could does'nt seem to be anything wrong there? Help, any ideas?
Old 03-13-2005, 06:44 PM
Kooterskkar Kooterskkar is offline
Send a message via AIM to Kooterskkar
Id say its a vacuum leak. When he put it back together did he replace the plenum gaskets? Can you hear any hissing sounds coming from around the top of the engine? Could also be the TB gasket or the EGR gasket.
Old 03-13-2005, 08:57 PM
cadgear's Avatar
cadgear cadgear is offline
Re: 97 Lumina fast idle, low acceleration
I agree with Kooter, it does sound like a vac. leak, be it from a line or from a gasket mating surface.
Old 03-14-2005, 01:18 AM
amac209 amac209 is offline
Send a message via MSN to amac209
spray around the engine with carb cleaner or wd-40. you'll know when you find it
Old 03-14-2005, 03:07 PM
Thanks for the quick reply's, gonna try to find if theres a leak after work today. I'll let ya know what happens.
