My 98 countour 4 cylinder won't start. pulled codes got cam or crank sensor replaced both and no go seems like timing is still off. i bought it broken like this for 150 $. It is getting spark. i Pressed the fuel bleeder valve and it squirts a little gas out. then stops after a second. checked the fuel shut off switch it seems likle it might be pushed down. i tried pushing it down but it won't budge. does anyone no the corect wiring or any thing else that could cause this or the values at the crank and cam sensors. also disconected the maf sensor. Tried starting spray no go. occasionaly i will get a backfire from the engine sounds like a sucking not a blast. please help.
your cam pulley may be a link off. There was some guy that had the same problems a while back where his 4 cylinder wouldnt start. Turns out his timing belt was a link off.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
how do I check this and can i do it myself. I have alot of tools should I replace the belt or stick it back on. I appreciate your help.
Re: 98 countour won't start HELP
stick it back on? do you have the timing belt off?
-Josh- 96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel 98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp. 01' Chevy Blazer, DD. |
I don't have it apart yet I meant how can i check to see if thats the problem. How can i tell if it skipped? and if it did skip do i put it back or just replace it? thanx
there will most likely be a "loose" section of belt. it wont be as tight as the wrest of the belt. check for an obsed amount of slack in one section of the belt.
I checked the belt and there is a 4 inch section of belt without teeth. IHow could that happen does that mean something locked up? also not sure if I am gonna fix it. I tried measuring the voltage at the coil and got 3 volts could this be from the ecm or pcm can some on measure thier voltage to make sure it is supposed to be more according to haynes. please help thanx
