Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-13-2005, 12:52 PM
deb1poet's Avatar
deb1poet deb1poet is offline
To DEXCOOL or not to DEXCOOL?
That IS the question!!
Did I finally get your attention???
I need some opinions from real users on what you would put in your OWN cars..........not what GM says, I have heard all the BS about that.
KISS: Keep It Short and Sweet :~()
Thanks
Deb
Old 03-13-2005, 02:24 PM
public's Avatar
public public is offline
Re: To DEXCOOL or not to DEXCOOL?
I converted mine to the green stuff, no more issues in either car. With dexcool one had gel and the other had tons of scale.
Yes, I am retarded.
Old 03-13-2005, 04:34 PM
deb1poet's Avatar
Thanks for your reply.
Old 03-13-2005, 05:51 PM
blazee's Avatar
blazee blazee is offline
Problem?
I converted mine to green stuff....no more problems.
If you want to convert you need to do a very thorough flush and get out all traces of the dexcool. If you don't, you will have more problems than if you had just left the dexcool in.
Old 03-13-2005, 07:32 PM
deb1poet's Avatar
Thanks Blazee
I was going to have a friend help me do it but now maybe I think I should take it to my mechanic.
Is there a product we could use to flush it out completely with?
Deb :~()
Old 03-13-2005, 07:46 PM
blazee's Avatar
Problem?
Converting may void your warranty.
If you want to do it yourself:
Buy the following:
Distilled water
Antifreeze
Prestone Flush 'N Fill kit $4
Prestone Radiator "Flush" $4
Turn your heater on and leave it on for the entire process
Drain the anitfreeze from the system.
Install the "T" from the Flush 'N Fill kit and follow the directions that came with it.
Disconnect the water hose, close all the drains, add the Prestone Flush, fill with water, get engine up to operating temperature and run for 20 minutes, allow to cool then, drain the system.
Connect your water hose to the Flush 'N Fill "T" and flush one more time. Drain.
Fill the system with a 50/50 mix of antifreeze and distilled water. Continue to fill the system over the next few days as the air is worked out of the system.
Old 03-13-2005, 09:50 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I have decided to keep the DexCool in my cooling system,BUT instead of following the now proven wrong timeschedule of 5/150, I will flush and refill every 2 years/ 24000 miles. DexCool's protection package is better for these engines and as long as you keep up on it there shouldn't be any issues. I have done extensive research both online and through other sources including speaking with radiator shops and cooling system experts, and weighing the pros and cons before coming to the conclusion to continue to use the DexCool.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 03-14-2005, 06:49 AM
blazee's Avatar
Problem?
The research I have seen shows that the standard green protects much better than Dexcool, due to the silicates that it contains. The silicates protect worn and pitted engine parts, Dexcool offers no protection for these parts.
Old 03-14-2005, 10:40 AM
Twitch1's Avatar
Twitch1 Twitch1 is offline
I run Dexcool in my aluminum radiator on the Eldo. Why? Two independent mechanics' experience and my independent radiator A/C shop I been going to for 25 years said it was better.
Dexcool will stand up to long mileage without change and not lose its protection integrity. I was told the 50,000 mile+ in system green stuff was the one they find turning to jelly not Dexcool.
Maybe more important in aluminum rads is the fact that it does not produce low power electrical field the way green stuff can and interfere with the zillion electrical thongs in today's cars. This is what these three shops have mentioned.
I use the greenie stuff on my old cars with copper rads but not the aluminum one.
Unless anyone foresees lots of coolant replacement incidents the cost diff is negligable amortized on a per mile basis for the life of the car.
1973 Z-28
1965 Nova
1950 Packard
1996 El Dorado Touring Coupe
There is no substitute for cubic inches
Old 03-14-2005, 11:16 AM
blazee's Avatar
Problem?
They are right about the Dexcool being better for aluminum than the green stuff, but the green stuff is much better for the engine. Even though GM (and a few people on here) denies this.....Dexcool has been linked to intake gasket failure. Ford made an announcement, when Dexcool first came out, not to use it in their engines, because their tests show it damages intake gaskets......this was before GM had any problems.
Even though it is suppose to, dexcool will not last any longer than the green stuff, because it is so easily contaminated.
Dexcool will definitely turn to sludge without the assistance of the green antifreeze. GM has made annoucements about this issue, stating that it is caused by air getting into the system and blamed two main causes:
The faulty AC DELCO radiator caps allowing the system to lose pressure and causing thousands of cars to sludge up.
People not maintaining their coolant level, thus allowing air into the system.
I understand you trusting a shop you have been going to for 25 years, but Dexcool has only been around ten years and the problems don't start immediately. So basically the only thing the shop that has 25 years experience knows about Dexcool is from the few GM car radiator problems it has seen in the last 5 years.
You can do a simple web search on "Dexcool" and get tons of info about the pros and cons of dexcool.
Old 03-14-2005, 11:44 AM
blazee's Avatar
Problem?
Feel like reading??
MACS 2001: GM and Texaco Bare All About DEX-COOL®
http://www.macsw.org/pdf/200410MS.pdf
http://www.consumeraffairs.com/autom...m_dexcool.html
http://www.wcpo.com/wcpo/localshows/.../20299ce7.html
Old 03-14-2005, 09:57 PM
deb1poet's Avatar
Thanks guys
Blazee very intersting reading indeed.
Deb :~()
Old 03-15-2005, 12:25 PM
MoNsTeR`ImPaLa MoNsTeR`ImPaLa is offline
Re: Re: To DEXCOOL or not to DEXCOOL?
from the first site on your list
What was said at the presentation? Besides the video, Jay and Stede included their personal observations about the study. At the end, they fielded several questions from the audience. Here’s a recap of their entire presentation.
1. Keep the cooling system filled. In fact, fill the reservoir bottle to “Hot” level when the system is cold. Problems arise when a system’s coolant level is not maintained. (Fleet vehicles receiving regular maintenance, and with reservoirs kept slightly above normal, do not show signs of contamination. This even applies to the specific “problem” vehicles.)
2. The coolant problems found in this survey were caused by system contamination, and not due to the breakdown of DEX-COOL.
3. Check and keep the pressure cap clean and functioning. A contaminated and/or malfunctioning cap causes low coolant levels, which in turn causes overheating and a greater loss of coolant: the notorious vicious cycle. No matter what the vehicle, if the cooling system acts suspiciously, test the pressure cap.
4. On the ST vehicle models mentioned in the GM DEX-COOL video, you “must” replace all suspect radiator caps, especially those with a Drop-Center design, with a Stant Model 10230 or 11230 (Spring-Center type). (Just do it.)
5. Make sure that the coolant is at a 50-50 mix. Often, the flush water was not being removed from the engine block. Consequently, when a 50-50 mix is added to the system the resultant mixture could approach 30-70. Like any fluid that has been diluted beyond its recommended levels, the lowered level of inhibitors will not be able to protect the coolant system effectively. Low levels of inhibitors can cause pitting on aluminum surfaces and general corrosion of cooling system metals.
this little report kinda takes away from the slamming of dexcool not that i support it or that i dont but im sure the issue GM has is a defective gasket material right
Old 03-15-2005, 12:27 PM
but wait theres more...........
7. Mixing a “green” coolant with DEX-COOL reduces the batch’s change interval to 2 years or 30,000 miles, but will otherwise cause no damage to the engine. In order to change back to DEX-COOL however, the cooling system must first be thoroughly drained and flushed.
8. Bacteria cannot live in a hot, Ethylene Glycol environment and is therefore not a threat to DEX-COOL.
9. While there have been intake gasket failures on CK Series, V8 powered vehicles for various reasons, DEX-COOL has never been found as a cause.
10. Use a refractometer to check the condition of DEX-COOL. Its inhibitor package is strong enough that if the batch still provides proper freeze protection, it is probably still providing proper corrosion protection as well.
11. DEX-COOL can handle the minerals in hard water better than silicated conventional chemistry coolants. Drinkable water is suitable for top off.
12. In ST Blazer applications where the radiator cap is mounted at an angle to the ground, the vehicle is more susceptible to radiator cap contamination and its related problems. The Stant 10230 is a wise choice for these vehicles. $$$
Old 03-15-2005, 01:16 PM
blazee's Avatar
Problem?
Yes that's what it says....what's your point?
