Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 03-13-2005, 10:11 AM
karaboo2000 karaboo2000 is offline
Windsheild washer
The front and rear windshield washer for 2000 Tiburon does not work or will not spray fluid. The reservoir is full of fluid. I don't seem to hear the motor pump working. Does anyone know where it is located so my dad can take a look?
Kara
Old 03-17-2005, 09:26 PM
twospirits twospirits is offline
Ex-Janitor of AF
Have you tried to check if you have any fluid in the reservoir. You may want to check the tiny holes to see if they are clogged. If so, clean them out with a toothpick or sewing needle. I had that problem on my Mazda and the needle trick worked.
TS out
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
Old 04-02-2005, 03:41 PM
tibby01 tibby01 is offline
Re: Windsheild washer
whoa, forgot about this section...
anyway, i dont suspect a clog, because the wipers themselves do not work and BOTH are not working. usually a clog would only clog one line.
i tried to find a picture for you but could not. just follow the lines running from the resevior. also check fuses.
Old 04-11-2005, 08:00 PM
Rickna's Avatar
Rickna Rickna is offline
IS-F
Did you check the fuses?
