Old 03-13-2005, 09:38 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Noise under the hood
Alright, here's my problem. Sometimes, when I accelerate, briefly I will hear a sound that sounds like a... can filled with change being shaken, that's the only way I can think of how to describe it. It occurs around 2 to 3 thousand RPM, and only does it when my engine is warm. When I first start my car and take it out for a ride, it never does it. And another problem is that sometimes I will get some white smoke coming out from my exhaust after I start my car. Anyone have any ideas as to what might be wrong?
Old 03-13-2005, 09:51 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Noise under the hood
Do you know if it sounds like its coming from your heads?. Does it only do it when its in gear or will it do it in Neutral or park as well?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-13-2005, 09:53 AM
blindeyed's Avatar
eBay aDdict™
Re: Re: Noise under the hood
Um, I'm not sure if it's coming from the heads or not. And yeah, I forgot to mention that it only does it while in drive.
Old 03-13-2005, 03:17 PM
volkerc's Avatar
volkerc volkerc is offline
the white smoke coming from your exhaust after you start your car is most likely just moisture trapped in your exhaust that burns off ones the exhaust warms up, as far as the noise is concerned, could be that you are using wrong gas, to low of octane or your ignition is a little off or a combination of both given you engine knock, ping...
Old 03-14-2005, 09:39 PM
blindeyed's Avatar
eBay aDdict™
Why would there be moisture in my exhaust? Is it really a problem I should tend to immediately or anything? And as for the noise.. would you consider my timing to be off even if it sometiems doesn't make the noise and sounds fine? I would try a higher octane gas (I use regular) if it weren't so expensive.
Old 03-15-2005, 04:32 AM
volkerc's Avatar
Re: Re: Re: Noise under the hood
moisture will always build up in the exhaust depending on the climate, lets say you drove your car, parked it outside overnight and the outside temperature dropped the cooling of the warm exhaust will leave some moisture in the mufflers...so many other possibilities, which i will not list, it is just natural, if you lose a lot of coolant, and you see white smoke in normal temperature (not when it's cold outside) then you might have a problem, but I assume you don't, as to the gas, check what type of gas the manufacturer recommends, if you don't use it yet, USE IT!. If you happen to use the correct gas already, then check your ignition....
Old 03-20-2005, 11:44 PM
86TA 86TA is offline
Send a message via AIM to 86TA
what year is it and is it a v6 or a v8? check and see if its your heat shield... thats a common problem, expecially among the 3.4l V6's from 93-97 (for some reason the worst on 95's) and usually on the passanger side manifold... sometimes it can be tightened down and fixed, and sometimes not... dont know why it happens or what makes the differance as to wheather it will fix it or not, but i would start there befor anything else... if it fixes it for a while, then starts up again - i wouldnt wreck my brain over it man... its nothing major unless the thing is totally loose and floping around in there, lol, which im sure its not or you would really know it... let us know if you figure it out... and good luck
-Dusty
Old 03-20-2005, 11:50 PM
cooltc2004's Avatar
cooltc2004 cooltc2004 is offline
Send a message via AIM to cooltc2004
LT1's need Premium Gas (92-95 octane). 3.1-3.8 can use Regular, and LS1, I am not sure about
Old 03-20-2005, 11:54 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
LS1 requires premium.
How does the car run when it is making said sound?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 03-21-2005, 12:00 AM
blindeyed's Avatar
eBay aDdict™
-Dusty
Yeah it's a 95 3.4L V6. But um, what exactly is a heat shield now?
Old 03-21-2005, 04:28 AM
volkerc's Avatar
a heat shield is a piece of metal that sits between the body and exhaust to keep heat from the exhaust away from the inside compartment, usually to be found at the catalytic convertor and mufflers
Old 03-21-2005, 06:44 PM
blindeyed's Avatar
eBay aDdict™
It runs perfectly fine, you wouldn't even think there was a problem with it at all.
Old 03-21-2005, 06:46 PM
blindeyed's Avatar
eBay aDdict™
I'm now currently using premium gas, and I'm still hearing the noise. So tomorrow on my day off, I'll take a look at the heat shield and see if that might be the cause. Thanks alot for all the help so far.
