Old 03-13-2005, 09:14 AM
BROBERTSON1995 BROBERTSON1995 is offline
Chrysler T & C electric window not working
I have a 2001 Chrysler Town & Country and the drivers side electric window is not working. When I push the button to roll it down you can hear a clicking sound coming from the button controller. I measured the voltage on the connector going into the window motor. When I push the button to roll it up, I am getting 12 volts. When I push the button to roll it down I get 1.2 volts for just a second and it goes aways the same time you hear the clicking noise. Any ideas?
Old 03-13-2005, 09:36 PM
lownloud lownloud is offline
well just a shot in the dark but maybe it is the motor on the power window regulator,bad motor itself or a stripped gear in it?
Old 03-15-2005, 08:37 AM
A. Souphound A. Souphound is offline
Re: Chrysler T & C electric window not working
The clicking sound could also be the window circuit breaker or relay. If the window or it's regulator binds it will kick the C/B, and then reset when it cools. Something is pulling too much amperage.
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 03-19-2005, 12:12 PM
mr_peretz mr_peretz is offline
I have the same problem with my T&C '01 passenger window. You can pull it up using the pass. side switch, but it won't go down. The switch on the left side door doesn't do anything at all. I brought it to the shop and the guy cheked everything and said the the switches are bad. I bought new pass side switch but problem is still there. Damn, this thing is driving me crazy!
Old 03-19-2005, 01:31 PM
Also, can it be that due to bad left side switch the right side is not working correctly?
Old 03-21-2005, 08:07 AM
Yes, if the Master control switch is defective, it can
cause problems with any of the windows. The Master control switch (11 pin) can be tested by continuity checks.
Alvin
