Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-13-2005, 09:37 AM
freebird0323 freebird0323 is offline
leak
i have a 1998 olds cutlass leaking coolant from around thermostate aer replaced temp senser any ideas
Old 03-16-2005, 05:02 PM
Manny_boy's Avatar
Manny_boy Manny_boy is offline
Re: leak
When you replaced your temperature sensor, did you coat the threads of the sensor with pipe thread sealant?
There is also a throttle coolant bypass hose, that is a good place for a hidden leak. worse senario, is that you could have a cracked intake manifold gasket. best way to pinpoint the leak is have a coolant system pressure test performed.
