Old 03-13-2005, 07:15 AM
ftj ftj is offline
1994 gran am
hello, i need the torque specs for rod,maim and head.for a 2.3 single over head engine. ty
Old 03-13-2005, 09:56 AM
Knifeblade Knifeblade is offline
Re: 1994 gran am
Piston rods Cap nuts/bolts~~~18ft.lb, then turn additional 80 degrees
Crank main bearing cap bolts~~~15 ft.lb, then turn additional 90 degrees
Head to block bolts~~~Bolts #1-#8 30ft.lb.s, Bolts #9-#10 26 ft.lbs. Then tighten ALL additional 90 degrees.
With front of engine pointing to the LEFT in this text
Bolt pattern is~~~~~~~~~
9 3 1 5 7
10 6 2 4 8
Hope this helps ya out
Tam
