Old 03-12-2005, 10:38 PM
jlcljayne jlcljayne is offline
Removing Engine Without Tranny?
Haynes says to pull manual tranny out with the engine...is this necessary on a 1988 1.5L FI with 5sp tranny? I would like to avoid removing the axles. Anyone with thoughts or experience with this?
Old 03-12-2005, 10:49 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Removing Engine Without Tranny?
In a civic IMP it is sooooooooooo much easier to take it out together.
If you want to attempt to take it out w/o tranny you need to remove crank pulley all belt driven things a/c bracket, motor mount bracket and just do a lot of wiggiling. It has been done.
But even the HONDA service manual tells you to remove the tranny with it. Now come on if honda tells you to most likely that is the easiest way!
Old 03-12-2005, 11:03 PM
Hybrid1990crx's Avatar
damn i would never want to do that, why dont you wont to remove the axles? its not hard.
Old 03-12-2005, 11:15 PM
Yeah when i was doing this to my integra I posted the same damn thread?
See searching would have helped!
Just pop axle bolt with a breaker bar and a pole (i used my trusty fence post 5ft!) and the bolt will pop right out. Then beat the hell out of the control arm to break the ball joint seal and pop those axles out. Its so much easier.
And besides it would be hard as hell to install a tranny while wiggling it aroung the engine!
Old 03-13-2005, 01:13 AM
arodg25's Avatar
arodg25 arodg25 is offline
dont waste your time. just loosen the transmision mounts and the engine will tilt. no need to take off your crank pulley or anything the engine will just come right out.
Old 03-13-2005, 09:19 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: Removing Engine Without Tranny?
ouch, i never do that
use a pickle fork to split ball joints instead man
alot easier IMO
Old 03-13-2005, 11:07 AM
Re: Re: Re: Removing Engine Without Tranny?
alot easier IMO
im with stupid on this one.
Old 03-13-2005, 11:13 AM
Thanks for all the replies....
Consensus is........pull tranny with motor!!!
Old 03-13-2005, 12:36 PM
Scott82 Scott82 is offline
i did it yesterday, it's not too bad a job.
Old 03-13-2005, 12:51 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yup i always pull hte whole thing out. like most people if they are changing clutch will just leave the motor in and just drop the tranny. fuck that i pull hte whole thing out. but thats just me
Team Lonely Drivers
Old 03-13-2005, 01:14 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
^^i second that
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-13-2005, 10:02 PM
kris's Avatar
kris kris is offline
Off playing with fire.
alot easier IMO
9 times out of 10 that tears the boot up though.
I have tried to pull the motor without the trans once, and it was a pain in the ass. So I say pull them together.
Now, here is a question. Do you guys go out the top, or down through the bottom? I'm a bottom person myself.
Old 03-13-2005, 10:21 PM
1PhatCX's Avatar
Re: Re: Re: Re: Removing Engine Without Tranny?
Now, here is a question. Do you guys goe go out the top, or down through the bottom? I'm a bottom person myself.
if u get a good enough fork it wont rip them
and i like it on top.. i mean, i like to take it out the top, funner that way lol, easier imo tho
Old 03-13-2005, 10:25 PM
I came out the top with mine too. It came out just fine.
Old 03-13-2005, 10:34 PM
Never tried the bottom but now that i think about it, it sounds easier. Cuz you always gotta tip it in at a nasty angle and level it in. from the bottom it will kindof just "drop out" basically.
Edit- would the radius rods or anything get in the way?
ZC stuff
