Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-26-2002, 01:09 AM
yaheardbish yaheardbish is offline
Send a message via AIM to yaheardbish
offset
hey my offset in the manuel says 46.. but i got 18x7.5 racing harts 37 offset. is that okay?? i mean will i have problems?
Old 03-26-2002, 06:25 AM
Luke@tirerack Luke@tirerack is offline
What type of vehicle ?????????????????????????????
Luke Pavlick
Objects in the mirror appear ... to be losing !!!
Old 03-26-2002, 09:39 AM
02 mitsubishi lancer
Old 03-26-2002, 02:15 PM
If you have a Lancer OZ or Lancer LS the minimum offset for an 18x7.5 wheel would be 42mm
If you have a Lancer ES the minimum offset would be 40mm
In either case the 37mm offset is lower than recommended and could cause several problems, including but not limited to: Tire rubbing when cornering or when the car is fully loaded, premature bearing failure, handling problems because of the alteration of the suspension geometry
Luke Pavlick
Old 03-26-2002, 03:49 PM
so if i buy h and r 5mm wheel spacer would this correct the problem?
Old 04-01-2005, 05:10 PM
modaddy04 modaddy04 is offline
offeset for 04 lancer oz
I have a 04 Lancer OZ with stock 15" rims/ 4 lug 4X114 and 46mm offest. Does anyone know if a set of ADR Intense (7spoke) 17" rims (same lug/bolt pattern above) with a 40mm offest on 205/45/17 tires will work? I was wondering if the front brake calipers would get in the way.
Wheel width/offset help Rooster32 Interior | Exterior | Appearance 0 04-05-2010 10:45 PM
OK, time to figure out which offset is really the best for the X FSRBIKER Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 12 10-10-2001 03:32 PM
Offset 93InfG20 Cosmetics 2 08-13-2001 06:47 AM
Helpful link on offsets, clearance, etc. Mythos General 0 07-27-2001 08:33 PM
Offset on old Pathfinder Rims ToeJam Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 07-23-2001 09:59 PM
