Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 03-12-2005, 07:42 PM
Dan65 Dan65 is offline
96 Concorde EGR problem
The check engine light came on, so I took the car to the dealer and they told me it had a bad EGR valve. The quote they gave me seemed kinda high...I thought I might like to try this myself. Anyone have any advice?
ALSO: There is a strong smell of gas under the hood and inside the car. I can't find a leak anywhere. Can this be realted to the EGR valve problem?
Thanks!
Old 03-12-2005, 08:16 PM
cbeck cbeck is offline
Re: 96 Concorde EGR problem
It can be related from what i understand, because it will keep the car from firing properly(dumps too much exaust back into the intake). I'm not sure what's wrong with yours, but if it's just sticking, I've seen suggestions that cleaning it with carb/choke cleaner will help.
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
Old 03-15-2005, 02:16 PM
AWP9521 AWP9521 is offline
It could be the EGR Solenoid/Sensor has gone bad, If the engine is a 3.5 it is located on the passenger side rear of the engine, it has a couple of vacuum hoses connected to it and a wiring harness connector. Not sure on the location on a 3.3 or if it even has one. The sad thing is to replace it you have to purchase the EGR Valve and the sensor as a unit, they are not sold separately and only through the dealer. Look to spend over 100 for the part. If the EGR Valve is still good you can just swap the sensor and the problem will go away but if the EGR Valve is bad then it will need replaced too and of course the new sensor comes with it. The EGR Valve on a 3.5 is bolted on the back of the passenger side Cylinder Head and again not sure on a 3.3' valve location.
Old 03-17-2005, 09:58 AM
Talking Re: Re: 96 Concorde EGR problem
Thanks to both of you for the info!
Old 04-07-2005, 02:09 PM
bjak bjak is offline
I was wondering if you changed out the egr valve. I am evaluating my egr valve on a 96 concord 3.5 and am curious as how the back pressure pipe is ported into the head? I connected a pressure gage to the egr back pressure outlet with the thought that I could also evaluate back pressure through the catalitic converter. I get no reading and am wondering if the back pressure port is blocked?
Old 04-08-2005, 02:03 PM
Re: Re: Re: 96 Concorde EGR problem
Sorry, I gave up and took it to the dealer....
Old 04-12-2005, 08:28 PM
1thunder 1thunder is offline
the back pressure port can be used to check exhaust back pressure just use an low pressure gauge and plug into back pressure port and snap throttle to wot rapidly should not exceed 1.5psi
Old 04-13-2005, 05:26 PM
Thanks for the info.
