| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
300zx twin turbo max boost
What is the max boost you can run on a twin turbo 300zx with all the main bolt-ons.( exhaust,intercooler upgrade, boostcontroller,intake,etc.
Re: 300zx twin turbo max boost
stock turbo's max out around 16-17 psi... but i wouldn't recommend pushing them much harder than 15 on a normal basis...
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
yeah, fuel injectors cant handle much past 15psi. once you upgrade those you could probably max out the turbos but i still wouldnt recommend it for standard driving conditions.
ZedEx Crew Member #4
when runing 1/4 mile ive seen guys running 18psi with ported turbos on stock injectors but i wouldnt recomend doing without risking damage
i run 15psi consistanly n havent tried to take it up yet, with the injector up grade i think you can run up to like 22-24
91 300zx twin turbo stage 5 [B.] Past Z Car Crew [/B.]
Re: Re: 300zx twin turbo max boost
stock turbos start losing there efficiency maxing them out at around 17-18psi...so with upgraded fuel injectors you could possibly run 18psi but once passed that your looking to deteriate the life of your turbos drastically, if the engine withstands the power. i personally would leave at about 12 or 13 psi and take up to 15 psi when needed...but i like to play things safe because bad luck seems to be my shadow.
