Old 03-12-2005, 05:17 PM
92firebirdman 92firebirdman is offline
not starting
im having the same problem as "c420has" . my car will not start, where do i begin my troubleshooting? my starter is less than 6mths old, alternator is 6mths old also. battery is fine, could it be the ignition switch? where can i find the fuses? could it be a solenoid problem?
please help, i love this car!
Old 03-12-2005, 05:46 PM
volkerc's Avatar
volkerc volkerc is offline
Re: not starting
you need to be more specific as to what your car is doing and what it is not...
Old 03-13-2005, 12:54 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: not starting
Answer these questions:
- When you turn the key to ON position, do the lights on the dash light up?
- When you turn the key to START position, do you hear a click, whirring noise, or both?
- If the engine does crank, does it do so slowly or quickly?
I can help you better if you answer those.
Old 03-13-2005, 03:34 PM
Re: Re: not starting
there is no sound when i try to start my car, when the ignition is in the on position, the radio ,lights,and turn signals work. when i try to start my car nothing happens. my car was running good before this happened. i went to start my car to go to work, i was letting the car warm up when it shut off. i tried to restart and nothing. this has happened to me before while driving, i popped the hood and noticed my alternator had lost some bearings from the backside of it. i replaced the alternator and the car ran fine. there is nothing wrong with this alternator as far as i can see? what are your thoughts?
Old 03-13-2005, 03:37 PM
the answer is yes to the first question.
the car does not make any sound when attempting to start
and the engine does not crank at all.
