Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-12-2005, 05:12 PM
brielly brielly is offline
Fuel Filter change
I'm going to changing the fuel filter on my camry 2.2 engine tomorrow and was wondering what the procedure is to discharge the fuel pressure. The haynes manual makes no mention of this but on my 92 celica w/ the same engine I had run it and pull the fuel pump fuse to relieve the pressure. Should I use the same procedure or just unbolt it and change it like it says in the manual? Thanks in advance.
Old 03-13-2005, 11:10 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Fuel Filter change
I would use the same procedure you did on your Celica. Also, make sure you do this on a cold engine. Sorry if that seems obvious, but you can't be too careful.
Mike
Old 03-13-2005, 04:53 PM
rum runner rum runner is offline
I always changed fuel filters until I got a 96 Camry. The service manager at the Toyota stealership said they never change fuel filters unless an engine is changed out. The fuel pick-up in the gas tank has a sock over it preventing trash from entering the fuel line.
Just a bit of information.
Old 03-28-2005, 01:47 AM
yoji6365 yoji6365 is offline
Re: Re: Fuel Filter change
Its not just the trash from the gas. They told me its also possible that you can get water in there and that doesnt help either.
But I wouldnt change the fuel filter unless I had to. Even at the recommended interval. I think its at 60k
But if you must, after you pull the fuse, start the car and let it run until it stalls, that way you get the rest of the fuel out of the lines.
I made a huge mistake by changing the filter without relieving the pressure. I dripped around 3 gallons before I finally got the filter back in place. If I read the darn manual, I would have either a) not done it b) at least not wasted the gas and set myself up for an explosion.
