Go Back   Automotive Forums Car Chat > Chevrolet > Corsica
Old 03-12-2005, 05:01 PM
Moneer81 Moneer81 is offline
Help! Changing brake pads for 93 corsica
hey guys,
I have changed brakes before but on foreign cars and that was pretty simple. I had no clue what to do to change them on my corsica. I have to somehow slide the caliper or take it apart, right? I only saw one screw on the top and oil started leaking out when I unscrewed it oil started leaking out, so I am assuming that something that has to do with the brake's oil. I need some help, or maybe links to sites that have pictures or illustrations, and that would be really appreciated. Thanks.
Old 03-12-2005, 09:50 PM
Kooterskkar Kooterskkar is offline
Send a message via AIM to Kooterskkar
Get a screwdriver, theres two rubber caps on the back of the caliper that cover the bolts. One on top, one on the bottom. You just pry the caps off. You will need a t50 tox bit to loosen the bolts. When you put the new pads on, put a prybar between the pad and the hub and push the pad back into the caliper then hammer down the tabs that stick through the holes. Id you dont do that they will rattle around and might even clunk when you hit the brakes.
Old 03-14-2005, 10:35 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Help! Changing brake pads for 93 corsica
buy a haynes manual$15. it sounds like you have no idea what you're doing.
