Old 03-12-2005, 04:09 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Turbo Needs
I have a 91 Eclipse GS and I was wondering if anyone would be kind enough to list off parts I need (not brands) to turbo my car. I would like for the list to be a little in depth so I can search the parts individually. I need all the stuff from valves, valve springs and retainers, pistons, rings, inter cooler, piping, etc. and I need quality to price is no option and I dont feel like buying a new car. I also looked at a DSM Thread but they dont have what I want so I thought you guys could help. It is greatly apprecitated and thank you again. I have a 4G63 NT thanks
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 03-12-2005, 05:40 PM
Gsx_hooptie Gsx_hooptie is offline
Note the quote:
"Turbo ECU or SAFC (to better control the fuel curve)
Turbo intake cam
Stronger Clutch
Exhuast manifold
Turbo
O2 Housing
Downpipe
Side Mount Intercooler, BOV, And all Piping
Knock sensor
MAS from a turbo 1g or a converted 2g MAS
Fuel Pressure Regulator (aftermarket)
450cc or larger fuel injectors and fuel pump
Boost Gauge, EFT Gauge, Air to Fuel Ratio Gauge
Stronger Pistons and rings (either forged(9.0:1) or 2g(8.5:1) or EVO(8.7:1))
MLS Metal head gasket"
by http://dsmtuner.com/forums/showthread.php?t=5986
Click there and you can even get a walkthrough, how fun. Search next time.
It really isn't that much, but it's under the assumption you'll be using the stock turbo or 16g. At least the injector size would lead me to believe that. Good luck.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 03-12-2005, 07:34 PM
EclipseOwn EclipseOwn is offline
Re: Turbo Needs
I see u have blue neon underbody kit. Where did you get it installed ?
Old 03-12-2005, 11:19 PM
Re: Turbo Needs
I did it myself its not hard. and I plan on replcing the injectors to. I am putting a T3 on.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 03-12-2005, 11:26 PM
gs-t spyder gs-t spyder is offline
Re: Turbo Needs
you may need a rise and rate fuel pressure regulator and a larger fuel pump a long with a turbo, exhaust manifold, custom made exhaust and intake piping, hsould have a intercooler. if i were you i would just look for a kit that someone makes for that, that would be your easies way out.
Old 03-12-2005, 11:30 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Turbo Needs
http://www.automotiveforums.com/vbul...d.php?t=200222
This was in the:
Important: ***FAQ*** Read this BEFORE you ask a question.
section.
good luck
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-12-2005, 11:31 PM
Re: Turbo Needs
yeah but I am doing this in steps the only reason I put money is no option is because im gonna be doing this for a while and I am planning on putting a T3 on so that link dosent help I have read it.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 03-14-2005, 09:30 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Turbo Needs
The manifold-turbo flange is different, the O2 housing is different, the oil feed is different, the oil drain is the same as 2g flange. Thats about it.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-14-2005, 08:00 PM
Re: Turbo Needs
your talking about the difference between the 2 turbos right, and All I need is the stuff listed off right just double checking so I dont have to do this again.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
