97 4.3 stumble on acceleration
My truck starts good no matter how cold, idles well but when taking off it seems to stumble. I can't get any speed out of it no matter how much throttle i give it. Once the engine is warmed up it seems to run fine and it picks up speed without a problem. Any ideas out there?
Re: 97 4.3 stumble on acceleration
Mine did the same thing... Always started, Idled perfectly... yet no acceleration and stumbled under any load (up a hill, etc.).
Turned out to be a partially plugged fuel filter. |
Maybe the thermostat is stuck open or not installed.
88' Chevy K1500 Silverado 350 V8 5.7 Original Owner 77,000 miles 2nd tranny Peeling Paint - Defective Factory Paint 235/85/16 BFG MT |
Re: Re: 97 4.3 stumble on acceleration
Well I would next check the CTS (Coolant Temperature Switch). Check the connection is not loose or corroded. The CTS can be ohmed out to test but I don't know the specs. If you replace it ($9 or so) use some teflon tape or thread sealer so it don't leak.
BTW, Let me try to explain my thought process here, it's the computer in open loop thats hunting for a air/fuel mix (choke) that works well from the input of the CTS. Once operating temp is achieved, via the CTS, the computer goes into a closed loop and monitors additional sensors, primarily from the o2 sensors for proper air fuel mix/ratio. At least thats my understanding, anyone can feel free to correct me. It's how I learn.
Thanks for the help. |
Should be on the front top side of the intake manifold, near the thermostat.
