Old 03-12-2005, 02:11 PM
RMORT RMORT is offline
Question pulsating brake pedal
My 03 cavalier has had the disc's trued-up twice now in only 16000 miles due to disc warping. Same problem with a 97 I used to have. And I am not hard on the brakes.. Anyone else have this problem??
Old 03-12-2005, 02:47 PM
Dasbogie Dasbogie is offline
Re: pulsating brake pedal
Funny you mention disc warping. Just had both rotors replaced because they were terribly warped. Also had to replace the pads because of uneven wear.
Old 03-12-2005, 05:16 PM
PsychoJJ's Avatar
PsychoJJ PsychoJJ is offline
Send a message via AIM to PsychoJJ
Had the same problem. Went out and picked up a set of hawk performance pads and brembo drilled and slotted rotors. So far everything is great and I break like a wacko.
Even pure genius is born out of insanity!
Big thanks to Lance for the sig pic.
Old 03-12-2005, 07:43 PM
Tookie Tookie is offline
Some years ago there were some major claims against tire "specialists" who's job was to replace and install tires on vehicles. The major complaint was premature wear and warping of rotors. It was discovered that in their efforts to make the process speedy, most "specialists" chose to use impact guns and the like to install the bolts onto the studs. You can imagine how tight these nuts were cranked on. Heaven forbid you had to remove a wheel. Most folks had taken to including a johnson bar; or a piece of steel pipe to attach to the nut removal tool included with the vehicle.
Reinstalling the nuts onto the studs was supposed to be finalised with a torque wrench or something capable of doing so to X number of foot pounds.
Needless to say, a lot of "specialists" got dinged pretty badly for an assortment of repairs including stud replacement, new rotors, brake shoes, and even damages related to loss of work pay and worse. All because a cheap tire jockey was portrayed as a "specialist". Next time, observe the installer as your tires are serviced. If you see him take anything other than a tool capable of properly torqueing on the wheel nuts, complain and go elsewhere.
HTH
Tookie
Old 03-12-2005, 08:51 PM
TunerAdept TunerAdept is offline
hey tookie, that explains why my rotors were going bad a while back >.<! thanks
2005 2.2L Ecotec Cavalier LS Sport Manual 145hp/155tq
K&N Ram Air Intake "Typhoon Intake"
*comming*
upper/lower poly mounts
header 4-2-1 1.5 primaries
remote exhaust cutout/ hi flow cat/ hi flow muffler/ larger piping
Racing Spec grounding kit
-----then the fun mods start, but one step at a time-------
