Old 03-12-2005, 11:17 AM
robinelmsdale robinelmsdale is offline
Question Power steering got me stumped
My 2000 SEL 3.8l power steering pump is noisy when driving and at idle. The fluid is always low and there is no indication of a leak, (no stains in driveway). Every <a href="http://www.ntsearch.com/search.php?q=time&v=56">time</a> I drive it I have to add fluid. Someone suggested that it may be leaking into the <a href="http://www.ntsearch.com/search.php?q=ram&v=56">ram</a> or filling up the boots!!!!!! 2 liters of fluid seems like alot to be filling up the boots.
Anyone have any suggestions before I throw it at a mechanic?
Also, is there anywhere here where I can view a drawing of the steering system?
Thanks
Old 03-12-2005, 07:28 PM
wiswind wiswind is offline
Re: Power steering got me stumped
The fluid is going someplace....you will want to find where. Perhaps it is leaking at a high pressure point....only when you are driving?
The steering rack is toward the rear of the bottom of the engine.....and the power steering cooler is in front of the radiator......point being.....there is a lot of territory to look.....
If the fluid has gotten low...it is very likely that you have gotten air into the system....which will make noise. The way to purge the air from the system is to turn the wheels fully in one direction, to the stop, and then to the other direction to the stop....do not rest against the stop....just touch it and then turn the wheels the other way.
Also, make sure that you use the correct fluid.
I think your 2001 calls for a Mercon Transmission fluid for the power steering.
If so, I would recommend Mobil 1 Mercon (can be bought at autozone).
Another recommendation would be Redline Power Steering fluid....but not as easy to find.
