Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 03-12-2005, 10:21 AM
kchast kchast is offline
Battery, Alternator or starter?
I have a '97 Dodge Intrepid with original battery and alternator (102K miles). If I ride for 1/2 hour or more, although all the lights, radio, etc work, the car will not turnover. But if I let it sit for a few hours, it will crank. Is it my battery, alternator or maybe starter?
Old 03-12-2005, 11:10 AM
aeromek aeromek is offline
Sounds like a poor battery connection. Your starter draws way more power when it is heat soaked. Check all your cable connections, especially the ground from the battery to the frame. It is almost always forgotten about.
It is the least expensive option to try.
Old 03-12-2005, 05:24 PM
Re: Battery, Alternator or starter?
Thanks for the advice. I tried that once before, but it didn't fix the problem. I measured the voltage and it reads 12.6 volts normal and 9 - 9.5 volts when cranking. So according to that other posting, I need to change the battery. I'll do this tomorrow and see.
Old 03-12-2005, 07:02 PM
1996tealblue 1996tealblue is offline
Wink Re: Battery, Alternator or starter?
If its the origional mopar battery it needs changed any how. I used a Walmart Everstart 1000 amp in my 96 and it fires instantly. This is my third battery! You'r lucky . Pat
Old 03-15-2005, 05:09 PM
djnitehawk djnitehawk is offline
Re: Re: Battery, Alternator or starter?
I had a similar problem to this after I replaced the alternator, battery and starter in a '94. Turns out that the starter was bad. If a new battery fixes your problem, great, but if not you may want to chack the starter.
Old 03-15-2005, 10:15 PM
Big Dan58 Big Dan58 is offline
Send a message via Yahoo to Big Dan58
Be careful with Walmart Batteries. I had a Walmart Everstart 1000 amp battery in a car that I just bought and it was only good for 2 years. Even with the receipt, I would have had to send it back to the mfr. for a limited warranty, plus I would have to pay for the shipping (on haz mat? No Thanks! big $$) You cant go wrong with a Sears Die Hard Gold! I have them in all 5 of my cars and have never, ever had a battery problem again! If you end up having a problem, Sears is all over the place, you just take it back to them. Your problem sounds like a battery problem. You might have a bad cell. If you have the original battery, you've done exceptionally well, and it's time to cough up some $$ for a replacement. My Mopar batteries went out after about 4 years. Remember, you get what you pay for.
Big Dan58
Panic, Chaos and Confusion... My work here is done!
Old 03-16-2005, 06:17 AM
FYI Sears don't make batterys. They just buy them from several manufactures in the us and others . Same as Walmart,Napa , Sears , Auto zone , Tractorsupply , Advance Auto. Kmart....
