Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-11-2005, 09:22 PM
sickrick111 sickrick111 is offline
Help!!!!!! rack pinion prob. S.O.S
Okay, I just bouht a 97 ford explorer 4X4, The rack and pinion seals work leakin so I replaced the rack and pinion unit, connected all the lines good and it took me like 3 days of work, filled up the pump res. and turned the wheel back and forth to fill the pistons, I filled re. to proper level then started it, heres were everything went in the shiter, as soon as I touche the steering wheel it whent nuts and keept going back and forth with alot of force and keeps going till I turn it off it scared the crap out of mee and almost took off my arm someone help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!
Old 03-12-2005, 05:55 PM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
Re: Help!!!!!! rack pinion prob. S.O.S
Did u bleed the air out of the lines?? Sounds like a lot of air is trapped in there.
Old 03-12-2005, 10:52 PM
how do I bleed a power steering system?
Old 03-13-2005, 01:38 PM
molehole's Avatar
I believe there was someone that posted how to do it a while back in the forums. Also you could try your local dealer and ask them how to do it. I think, there is a bleeder screw somewhere on the steering box but I am not sure. Good Luck
Old 03-19-2005, 07:53 PM
Lines were crossed, my stupid mistake, fixed it and works fine, thanxs for your help guys
Old 03-19-2005, 08:25 PM
molehole's Avatar
THats good. Good Luck
