Old 03-11-2005, 09:17 PM
Yungstar007 Yungstar007 is offline
Send a message via MSN to Yungstar007
Re: Crackling sound when starting up
Hi everyone,
For the past while I've been experiencing a very loud crackling sound coming from the engine when I initially turn the car on. It usually occurs for about 2-3 seconds, and only happens when the car is semi-warm or warm. I never hear it when the engine is cold.
Last week I took it to Mitsubishi and even they could not figure it out. They originally thought it had something to do with the exhaust, but even they weren't sure about it. The mechanic said that the sound didn't last long enough for them to distinguish where exactly it was coming from. If I have my driver side door open, and start it up when the sound is occurring I can hear it from right under the car on the driver side, but I can't pinpoint it either. It literally sounds like firecrackers, especially when the base of wherever I'm parked creates an echo.
I've done searches but they don't seem to be of the same problem. I've heard all kinds of suggestions from the t-belt, exhaust, alternator, flywheel to the spark plugs.
I guess I just want to know if it's just a common sound, or if this is a prelude to something that might be a problem (if it's not already a problem.)
Any suggestions or advice would be great. Like I said, it only occurs when the car is started (when warm), for 2-3 seconds, then goes away.
Thanks in advance.
My ride:
1998 Eagle Talon TSI AWD - Standard
Old 03-11-2005, 11:04 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: Re: Crackling sound when starting up
Check your pms...
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 03-12-2005, 01:36 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
i had the same problem too....hasn't done it this winter, but always did it alst summer....the sound only occured right when i started it and lasted 2 seconds at the most. no clue of what it could be, but if you find out, fill me in.
Old 03-12-2005, 07:08 AM
macder macder is offline
Send a message via MSN to macder
My guess would be that it's your starter.
BTW, I think your sig picture is way to BIG
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 03-12-2005, 05:58 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
I had kind of the same problem, but mine happend when it was cold! I had the starter rebuilt and it fixed the problem.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 03-12-2005, 10:13 PM
my pic? it's just fine for me of course i'm probably running a much higher res than you are.
Old 03-13-2005, 04:29 PM
Not your pic, Yungstar007 pic, but i see he fixed it.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 03-14-2005, 03:47 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
check your relay or your starter.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
