Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-11-2005, 07:45 PM
s13dr1fter s13dr1fter is offline
Send a message via AIM to s13dr1fter Send a message via MSN to s13dr1fter
sr20 or rb20
OK I have a question for u guys what would be faster the sr20 or the rb20 stock? Can the rb20 drift like the sr20 can? What is the max power a rb20 can handle? The reason why i'm asking because i havea buddy that has a rb20 front clip that he wants to sell. So if the rb20 motor can beat the sr20 i'll prolly gonna grab it.
Old 03-11-2005, 08:27 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
Re: sr20 or rb20
its not the engine that drifts its the driver that drifts
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
Old 03-11-2005, 08:35 PM
Re: sr20 or rb20
yea i understand that... but hmm what about 1/4 mile race.
Old 03-11-2005, 08:48 PM
Chuki_breath Chuki_breath is offline
Re: sr20 or rb20
hmmm good q. Most people will probably tell you to go sr because well the parts are way easier to find and upgrade compared to the rb20 (stateside that is). I would go rb20 if you can get a deal on it. Parts are not totally unfindable. But if you want less of a hassle i would say sr20, just because everyone and there grandma wants one now and there just more popular. But if you want to be a rare guy, then rb20.
Old 03-11-2005, 08:56 PM
Re: sr20 or rb20
yea i can get the clip for about 900 bucks. But i think i decided since i got 2 240's one will be sr20 and the other ka-t. But thanks alot for the suggestions
Old 03-11-2005, 09:44 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: sr20 or rb20
RB20 has more low end torq.. u can put a bigger Turbo on it, + i think its a steel block right? so it can handel more boost..
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 03-11-2005, 09:57 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: sr20 or rb20
if you can get the rb fuckin spend the money
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 03-11-2005, 10:01 PM
D-Bo's Avatar
Re: sr20 or rb20
i'm fuckin bombed
Old 03-11-2005, 11:08 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
Re: sr20 or rb20
6 cyl vs 4 cyl
both turboed
rb hp > sr hp
sr = less hassle, more install intructions
rb = handle more power, most likely (good guess)
sr - JDM DriFFFTORRS
rb - weighs a bit more but i think drifting in it should be managable
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 03-12-2005, 12:53 AM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
RB20 HP=SR20 HP
roughly anyways
its an iron block i think, but built up the sr and the rb could sustains comparable boost, the sr20 has a much better aftermarket, the rb would spool larger turbo quicker being 6cyl
the rb20 is a fairly easy install though, its the closest thing to stock fit in the 240 out of the rb series, not an extreme amount of modifications to fit it
the repair costs would be higher though as parts would be harder to find, and you would have to order them directly from japan yourself probably
Old 03-12-2005, 12:54 AM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: sr20 or rb20
2.0l of airflow is 2.0l of airflow no matter how many cylinders it passes through.
2.0*61.02=122.04 or 122CID
divided by 1728cu ft=.0706
*7500rpm=530CFM
divided by 2=265CFM
multiplied by .069lb min=18.2lb/min.
1lb/min of airflow is approx=10hp
Now a given engine that flows 18.2lb/min of air is going to make 182BHP no matter how you look at it or how many cylinders it has. The only other factor to be considered is VE. But the only thing to be affected is power curve. Which the RB will have a smoother one, but no more power is to be expeced.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 03-12-2005, 01:05 AM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
Re: sr20 or rb20
built, both motors handle just about the exact same power.
438whp / 373tq - 11.9 @ 126
Old 03-12-2005, 11:08 AM
Re: sr20 or rb20
If both motors were built i would think that the rb20 would faster than the sr and make more power.
Old 03-12-2005, 06:57 PM
240SX Guy
Re: sr20 or rb20
And you are free to think that, but its incorrect. Your car, your engine. Do as you wish.
-Cory
12.6@122mph
Old 03-13-2005, 12:01 AM
thegladhatter's Avatar
thegladhatter thegladhatter is offline
Re: sr20 or rb20
The RB is just to freaking huge for the 240sx. It is the same size in displacement but it is just enormous in actual size. It weighs more and the good points don't make up for the physical size. Go SR. You'll be glad you did. BTW I own both. The SR is my preferred weapon of choice.
