Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-11-2005, 07:29 PM
Jus--10 Jus--10 is offline
take door panels off
I have a 92 caprice, and I have to take my front door panels off, just wondering how to do that? i cant seem to get it off, and I don't want to break anything, any help would be appreciated.
thanks!
Old 03-13-2005, 10:49 AM
nobody can help me here?
Old 03-19-2005, 12:46 AM
LTZ9C1 LTZ9C1 is offline
Try getting a Chilton's or Haynes manual for your Caprice door removal situation. They basically tell you step by step what to do.
Best thing I ever did
Old 03-19-2005, 07:44 AM
CD Smalley CD Smalley is offline
Re: take door panels off
I assume the later cars use the same stupid little tabs that twist into the door panel and then wedge into the door frame.
I have made a habit out of buying new tabs before I start this job, you'll need 10 or more I'd guess.
Then I take an old screwdriver that I have ground the tip to a flat sharp edge. Next start at on end of the door and gentyl pry it up with your fingers. You'll be able to see where the tabs are at. Now stick the sharp edge of the screwdriver I mentioned up against the tab. Not hit the screwdriver with a hammer until you break thru that tab. Repeat as needed on each tab.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 03-19-2005, 11:15 AM
burnM's Avatar
burnM burnM is offline
You could pick up a panel removal tool... It basically looks like a screwdriver but it has a slight bend at the end and the tip is is about one inch wide split in two. I picked mine up for about 2-3 bucks. The door panels on these cars are cheap, so take your time. Take out all of the screws that you can find in the panel (behind the handle, in the armrest padding,etc.) and like CD said, get some extra "trees", 'cause you're going to need them.
When the whole panel is loose, you'll find that the top of the panel where it meets the window will be hard to remove. Roll down the window, and as you push up on the panel, give it a slap along the top edge. This should enable you to release the tabs at the top of it, and VOILA! you have a removed panel! (works for me, anyways)
Slide your hand behind the hanging panel, and carefully release all of the electrical connections. The plastic clips that hold the connections in place will more than likely be brittle from age, so again, be careful, and take your time....
Hope that helps....
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 03-20-2005, 12:13 PM
thanks a bunch, I got the door panel off, now time to replace my window motor
