Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-11-2005, 08:00 PM
94talontsi89's Avatar
94talontsi89 94talontsi89 is offline
Send a message via AIM to 94talontsi89
turbo charger question
ok I was looking at cardomain and I saw a guy with a single turbocharger and it had the double airfilters on the one turbo charger. I was wondering if I can do that or will it be to much air for it?
http://members.cardomain.com/98talonesi89
Eagle
Talon Esi
1998
5-speed
dohc 2.0L 16 valve
all stock (for now intil summer comes)
Old 03-11-2005, 08:29 PM
awd_n_it awd_n_it is offline
Send a message via MSN to awd_n_it
There no such thing as "to much air" when it comes to air filters. as long as you keep your mass air flow sensor on your car you can put ant type of filter that you can fit on there.
(Early) 1992.5 Eagle Talon
TSI AWD 5 Speed
Old 03-11-2005, 09:45 PM
ok cool
Eagle
Talon Esi
1998
5-speed
dohc 2.0L 16 valve
Old 03-11-2005, 10:22 PM
northriverflames northriverflames is offline
Send a message via MSN to northriverflames
Re: turbo charger question
So does this mean it may run better with two filters on it?
2000 Chevy Silverado 1500 4x4 Extended Cab.
1996 Pontiac Sunfire GT 5 Spd.
1992 Plymouth Laser RST AWD 5 Spd.
Old 03-12-2005, 12:59 AM
joemathews's Avatar
joemathews joemathews is offline
Just use a nice big K&N style filter--no need for two. Look at the setups of the "fast guys" and you'll see that you don't need more than one filter
Brent Rau has his turbo mounted ram-air style, with a custom hood that scoops air right into the compressor housing, no filter at all Not a good idea for daily driving, though
1996 Eagle Talon
Old 03-12-2005, 04:17 AM
kjewer1 kjewer1 is offline
AF - Advisor
Two would be hard to fit in our case. Check out my site for pics of a large filter. Its about 10 inches long, 7 inches in diamter (just fits), with a 4" connection, in my case. It was about 35 bucks at summit, they're all about the same price. Fit the largest filter you can. I had to cut my 4" intake pipe about 5" shorter to fit this thing. With a stock MAS you are limited to how long you can go. But the name of the game is surface area, doesnt matter which particular measurement you increase to get it
Edit> WTF is with all my editing tonight? So, if a 7" diameter filter will fit, even if its still only 6 or so inches long (not sure what that number is), and can be bought with a 3" inlet (to fit most of the round MAS adapters available), its better than the smaller cone type filters I see some kits coming with and I Would go for it.
Its the same principle as larger intake pipes. Turbos are pressure multipliers. Pre turbo restrictions provide a vacuum on the turbo inlet, which is another name for negative pressure. So your turbo needs to run at a higher pressure multiplication ratio (left line on compressor maps, go up, and you see efficiency drops) to get the same given boost pressure level. Freeing up preturbo restrictions is like lowering the boost. Less heat, less chance for knock, but more airflow to the motor.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
