Old 03-11-2005, 06:43 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Cleaning
i have got a couple questions.
when installing water pump should i use some kind of sealant or is gasket enough?
what should i use to clean injectors.they are removed at the moment and dirty as
F#@k.
rear main seal is seal on oil pump correct?
what sealant should i use for oil pump?
and last, what should i use to clean TB and inside manifold?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 03-11-2005, 07:53 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Cleaning
F#@k.
grab some injector cleaner and soak ur injectors in that
shit, that reminds me, i've had some soaking for a week now lol
rear main is the one by the flywheel, its the rear main crank seal
usually use a gasket sealer on the water pump as well, its usually a good idea
for the tb and manifold, use tb or carb cleaner, either one works
have fun
Old 03-11-2005, 08:20 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Cleaning
the gasket is enough for the water pump but usually its hard to get the gasket to stay on there. i use rtv water sealant. around just to keep it on there.
get a bottle of injector cleaner dump it into a small enough container to fit an injector, then fire the injector in the cleaner. i know theres something else you can use but i forget what it is
oil pump is on the front of the motor so its the front main seal
for oil pump use hondabond.
carbcleaner should work good
Team Lonely Drivers
Old 03-11-2005, 08:24 PM
Jos4DCivic's Avatar
the whole injecter is to be submerged? aslo for carb cleaner i can spray inside manifold?
91 Hatch SI
Finally painted!!!
Old 03-12-2005, 01:38 PM
1PhatCX's Avatar
Re: Cleaning
yes and yes
Old 03-12-2005, 03:16 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
well, dont submerge your hands with wires to fire it. lol
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-15-2005, 01:50 PM
Jos4DCivic's Avatar
Will RTV work for oil pump?
91 Hatch SI
Finally painted!!!
Old 03-15-2005, 03:02 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Cleaning
lol jos dont your local store help you out on what to use on oil pumps...ya i know they dont get paid enough to answer to many questions but i am sure they will tell you best of there knowledge...haha...rtv depends on what sealant it is
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
