Old 03-11-2005, 05:57 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Factory alarm?
Did all VR4s come with a factory alarm? I have a keyles entry but its a pain and only works when I'm right next to the car and it dosent set off the alarm if I just open the door, it also dosent lock itself if I forget. If they came with one how can I turn it on? Is there any way to be able to use the crappy little controller from a distance (I tried changing the battery but it didn't help much).
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 03-11-2005, 06:42 PM
sLADe781 sLADe781 is offline
Re: Factory alarm?
A lot, not all of course, of stock alarms are pretty crappy. But the fact that you say your alarm doesn't go off when you open the door is kinda weird....doesn't that defeat the whole purpose of having an alarm? LOL Anyways, it may be your trigger. My triggers are kinda worn so sometimes when I open the door, my alarm doesn't go off because my trigger wasn't triggered (ok, that sounded redundant). But yeah, maybe get an aftermarket one?
Old 03-11-2005, 07:07 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Factory alarm?
Its a passive alarm. If you want to try it out put your window down and shut the door and lock it with the remote or lock it then shut it. Without unlocking it reach inside and pull the handle to open the door. It should start going off.
To disable it shut the door and either lock it and unlock it with the key or remote.
Old 03-11-2005, 07:16 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Factory alarm?
Yeah what Stealthee said...mine only works from like 10 feet away max. It kinda sucks, but then again what do you need it for from any further anyway. The door triggers go bad, mine are bad, and as a result it doesn't "detect" the door opening which makes the alarm useless. I'd suggest you go to the dealer and order some new triggers...there's one for the trunk too, although I don't know where, I just know it set my alarm off once when I opened the hatch. I still don't know how to turn the alarm off once its going, other than disconnecting the battery which is a pain.
Old 03-11-2005, 07:40 PM
Thourun's Avatar
Re: Factory alarm?
Yea I just opned up my remote (only one, need to go to the dealer to see what I need then Ebay lol) to clean the contacts and theres one labled trunk but it dosent have a button over it lol.
1995 3000GT VR-4
Old 03-11-2005, 07:44 PM
Re: Factory alarm?
Try unscrewing the door triggers and screwing them back on. Because at first, both of my triggers were really bad but I managed to unscrew my driver side one and I think it might have loosened some rust or something because it works fine now. The trigger on my passenger is still crappy and I haven't been able to unscrew it. They're really tough to unscrew....at least mine were.
Old 03-11-2005, 07:50 PM
Thourun's Avatar
Re: Factory alarm?
I'll try what stealthee said first.
1995 3000GT VR-4
Old 03-11-2005, 08:50 PM
Re: Factory alarm?
yeah I broke one screwdriver trying to unscrew the driver one, finally got it off with a bigger one.
Old 03-11-2005, 09:55 PM
Stealthee's Avatar
by trigger I am assuming you mean thedoor lock actuator?? What exactly do you unscrew? My drivers side lock doesnt like to lock all the way when its cold.
Old 03-11-2005, 10:17 PM
Re: Factory alarm?
When I say trigger, I'm referring to the "pushy thingy" near the bottom of the sideskirt. It's covered with a rubber top but if you take that out, you'll see the trigger and some screw there.
Old 03-11-2005, 11:46 PM
Stealthee's Avatar
aha! Yah mine sticks sometimes. I pulled the boot off and lubed it up with wd-40.
Old 03-12-2005, 02:23 AM
G35turbo G35turbo is offline
Re: Factory alarm?
what i hate more than the distance problem is that u r light dosent flash or it dosent horn if the door is locked or unlocked. so basically if your not near the car u r not going to know if the door is locked or not.
Old 03-12-2005, 10:36 AM
Re: Factory alarm?
yeah thats true, the interior lights flash, but that's only good for night.
Old 03-12-2005, 05:51 PM
crazy_quick crazy_quick is offline
Re: Factory alarm?
I got a factory alarm but I got no keyless entry, turning the key in the door turns off the alarm.
Old 03-12-2005, 07:55 PM
Thourun's Avatar
Re: Factory alarm?
Wierd, I should go by the dealer and check out what I have and get another remote.
1995 3000GT VR-4
