Old 03-11-2005, 04:55 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
Question timeing
did major head work on the 3 cyl the timeing has to be set at 10 deg. but still needs to be advanced more but the dis dosent go any further what do you think could be wrong ive double checked every thing
Old 03-11-2005, 05:12 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: timeing
did you short across the connector at the firewall before you checked the timing. if you did and its still needs to be moved further sound like you got belt off a tooth
Old 03-12-2005, 10:04 AM
Re: timeing
yes and i checked the belt several times but i am unsure of the mark on the crank pully im used to it beeing a notch and this just has a little scratch type thing where should the mark be in relation to say the belt gears key way ?
