Old 03-11-2005, 04:55 PM
mvette76 mvette76 is offline
engine swap
have 91 rs camero with v6 putting in a zz4 with a hot camshaft want to know if the electric fuel pump will still work without the computer to supply feul for the carburator?
Old 03-11-2005, 07:58 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: engine swap
youll probly want to wire a switch to supply the power to the fuel pump. The fuel pump is just an electronic motor, so if you run power and ground to it, it will run, you just need to figure out how to turn it on and off. dash mounted switch probly is just as good as any other idea.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-20-2005, 07:10 PM
Vortec350S10 Vortec350S10 is offline
Re: engine swap
If your running a carb on your ZZ4 you will need a fuel pressure regulator cause your electric pump puts out way too much pressure for a carb. I have seen them in Summit for around $100. I'm not sure on the exact pressure but its probably over 30psi. A carb needs around 5psi.
'89 S15 4x4 350TBI/700r4
restored body, paint,
3" lift, crane cam, vortec heads
'88 Iroc 350 carb, TCI 700r4, 380hp
Old 04-21-2005, 12:12 AM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
i just found the power to the fuel pump, disconnected the relay and ran an in-cabin switch. that worked well.. also about the fuel pressure go to summit grab a holley one for 26$ itll work perfect, idk where the 100$ comes in thats probly for the pro ones, also ur need to regulate 5-7 psi from the 32-36psi coming from ur electric pump.
