Old 03-11-2005, 03:47 PM
ChrisAVI ChrisAVI is offline
2001 Caravan Stalling
I have a 2001 Caravan 49K miles 2.4, 4 cylinder stalls when idling and then it does not want to start right away. Runs fine on the highway and idles fine when it does idle. Replaced the fuel filter and that made no difference. When it does stall I turn the key off and on and I think I hear the fuel pump kick on then off again. I put the computer into self check mode and there are no error codes. Where should I start looking next?
Thanks
Chris
Old 03-11-2005, 05:26 PM
A. Souphound A. Souphound is offline
Re: 2001 Caravan Stalling
Thanks
Chris
Air Filter, Vacuum Leak, Sparkplug/s, Sparkplug wires?
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 03-11-2005, 07:54 PM
Re: Re: 2001 Caravan Stalling
Thanks for the tip I will look into the vacuum leak, everything else seems fine. It’s just strange that it happens all of a sudden without warning. Could it be a sensor problem?
Thanks
Chris
