Old 03-11-2005, 02:55 PM
RG501 RG501 is offline
Send a message via AIM to RG501
sterio and speakers
when im playing my music in my car loud, like around 80% of the total volume, my speakers start to make this poping noise. i dont know what is causeing this. i checked the speakers and they are not blown or anything. my sterio says 45 X 4 on it and the speakers say they can handle 80watts. so the speakers should be more then strong enough to handle the 45 X 4. any ideas on whats making this "popping" noise?
Old 03-11-2005, 02:58 PM
Re: sterio and speakers
on the speakers, it says:
peak power: 260watts
rated power: 80watts
Old 03-11-2005, 04:10 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Your H/U is only giving at the most 20wrms. Amp those damn things
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 03-11-2005, 07:52 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Internal amps on head units normally clip at like the 60-70% of total volume control value
Old 03-12-2005, 09:19 AM
so what your saying, i need speakers that can handle more watts in order to listen to louder music without the "popping" sound?
Old 03-12-2005, 03:18 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
there are 2 ways that a speaker can blow, thermally and mechanically
thermally is when you send too much power to the speaker and they overheat, melting the glue on the voice coil which allows it to unravel and cause all sorts of problems, or it can just plain melt the coil and short it out. This is the 80rms power rating that you see.
mechanical is when you send too much power at too low of a frequency and your speakers hit the limits of the suspension (aka "bottoming out", similar to bottoming out your car's suspension if you hit a huge bump). This is completely frequency dependent, and at low frequencies your "80rms" speakers could hit their mechanical limits at 10rms or less. Very few companies will actually tell you the speaker's mechanical power handling. The main thing to keep in mind is that you can't crank up the volume on bass-heavy material, if you hear your speakers "popping" then chances are they're bottoming out and they have a VERY good chance of breaking when you're doing this. An amp won't help you since your headunit can supply more than enough power to make the speakers hit their mechanical limits, what you need is a highpass filter that cuts out the low frequencies. If your headunit doesn't have any highpass filters built in then you can buy "bass blockers" locally, which are just a cap that sits in series with the speaker and acts like a simple 1st order highpass filter.
at 80% volume your headunit is probably clipping as well which can overheat the speaker's voice coils pretty easily. It also makes them sound like ass, but in my experience it won't make a "popping" sound. A more powerful amp would let you listen at this same volume without the clipping, but if the popping is from the speakers bottoming out it won't fix that.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-12-2005, 10:52 PM
thanks for the info, sr20de4evr.
so if i get better speakers with more "rms" power, the "popping" and "clipping" noise will stop? or at least get quieter?
Old 03-13-2005, 12:08 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
basically what you need is a high pass filter for you speakers and a dedicated subwoofer for the lows.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 03-13-2005, 12:33 AM
sr20de4evr's Avatar
Re: Re: sterio and speakers
probably not, chances are the mechanical limits will be pretty similar unless you really step up a few levels (not just a higher power rating, an all around better speaker)
'01 Black Sentra SE
'05 Silver WRX STi
Old 03-13-2005, 12:41 PM
so could you give me a link to better speakers?
Old 03-13-2005, 01:42 PM
sr20de4evr's Avatar
I would need a price range
'01 Black Sentra SE
'05 Silver WRX STi
Old 03-13-2005, 07:38 PM
umm, i dont know. nothing too pricey. do you have AIM so we could talk about this on there and talk faster?
Old 03-13-2005, 07:50 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
AIM: ngbd13
I'm on a lot...always have a message up...feel free to message me anytime!
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 03-13-2005, 08:15 PM
sr20de4evr's Avatar
yeah, and normally I'm on a lot, but not this week. ngsm can help you on AIM though
'01 Black Sentra SE
'05 Silver WRX STi
Old 03-15-2005, 10:22 PM
germanyt germanyt is offline
sounds like your just getting some really bad distortion. what could be happening is basically you are asking your h/u to send a clean sine wave at higher output than it is capable of producing thus causing clipping to occur. speakers dont like square waves. i suggest getting a small 4 channel. it should clear up the problem. and manny is right, even though your h/u says 45/4. youre not putting it out that much. probably somewhere between 14 and 22 watts rms. my best guess is an underpower problem
