Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-11-2005, 02:47 PM
hymes hymes is offline
95 explorer instrument cluster
I have one of the automotive books for the explorer and I have read several of the threads that pertain to the instrument cluster. What I need are the details on how to get to the cluster.
The book has you remove the lower pannels which I can do. Then you are suppose to remove the upper pannel. This is where I have the problem. I can remove the visible screws underneath the top edge as well as the screws at the stearing column area but the pannel still won't come off.
There appears to be a connection "behind" the bezel that goes around the radio area but no mention on this having to be removed. So I assume I am still missing some areas to unscrew before the top pannel will come off.
What I need to do is replace the BULBS.....
thanks for you help
Alan
Old 03-16-2005, 06:00 AM
PJ8847 PJ8847 is offline
several bulbs went out in my dash on my '95 Exploder as well, you have to remove the radio/heater bezel as well as the other panels in order to remove the the dash panel covering the cluster, If i remember correctly, there is a screw underneath that can only be accessed by removing the radio/heater bez.
Old 03-16-2005, 06:30 AM
Re: 95 explorer instrument cluster
That's kinda what I figured, but HOW do you remove the Radio/Heater Bezel? Do you have to remove the RADIO first? Or does it just "unsnap"?
Thanks
Alan
