Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-11-2005, 12:20 PM
1stgen gsx 1stgen gsx is offline
Send a message via Yahoo to 1stgen gsx
Exclamation Weird nose
Ok i just changed the timing belt and other belts around it i started the car after i was done to see if the timing was off it wasnt but then i hear this noise sounds like it comming from the exaust cam but i cant tell i also changed the cam seals too since i had a oil leak the car runs fine no oil leak or nothing i dont know but the noise is very loud and i lubed the rubber cam seals and everything i dont know what is going on can someone help me out? oh yeah the timing belt cover is it ok to leave it off or should i put it back on?
Old 03-11-2005, 01:08 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: Weird nose
does you belt have a little slack?
....It has been a LONG time...I want to move to FL or Japan.....
Old 03-11-2005, 04:22 PM
Re: Weird nose
it has a little bit not to much i put it to tight and the belt was smoking so i losened it a hair but that wasnt the problem
Old 03-11-2005, 08:27 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Re: Weird nose
keep the timing belt cover on if you dont something could just pop up get into your timing belt break it and there you go you have to relpace the engine, it would suck. my timing belt broke and I bent the rods and snaped the connecting rods I would keep it on.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 03-12-2005, 02:53 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Weird nose
I was expecting to see a picture of you in this thread, figured you were Italian or something.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-12-2005, 03:08 AM
drewh4386's Avatar
Re: Weird nose
i just noticed it does say weird NOSE. sorry i was diagnosing you problem wrong. No really did you ever find out where it was really coming from?
Old 03-12-2005, 09:28 AM
well it sounds like it is comming from the left cam but them i look under the wheel well and it sounds like it is comming from under the cam sprocket maybe i have to lube something i really dont know im going to have a good friend come over and check it out today ill let you know what is was that was making that sound ok prob something simple
Old 03-12-2005, 09:22 PM
AF - Advisor
Re: Weird noise
Please use punctuation. Studies have shown that poeple with DSM problems are 647% more likely to find solutions when using good grammar/punctuation.
Kevin Jewer
Old 03-13-2005, 09:00 PM
Re: Weird noise
Ok i found out what the problem was on my car was it was a tensioner pulley baring i had to replace the pulley. That fixed my car now it runs so much better.
