Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-11-2005, 10:29 AM
mitchdakid mitchdakid is offline
Catalitic converter
Have a question about my cat. I want to take it off but the bolts are stuck, and I don't know what to use to get them loose. I am using air tools and still can't break them loose any ideas on what to do. I am going to put on a performance cat or just straight it, I don't have to pass emissions so it's not a problem.
Old 03-11-2005, 02:02 PM
SSZero's Avatar
SSZero SSZero is offline
Re: Catalitic converter
If you're going to weld a straight pipe, you might as well just cut the pipe... If you want to do a bolt-up job, just get a lot of WD-40 and keep using your air tools to take the bolts off. Eventually it should come off. If it doesn't, spray it as much as you can with the WD-40...
'96 Green Eclipse GS-T
Stock for now...
Old 03-11-2005, 02:56 PM
awd_n_it awd_n_it is offline
Send a message via MSN to awd_n_it
You can also try heating the nut up tell it gets red hot, then use the impact.
(Early) 1992.5 Eagle Talon
TSI AWD 5 Speed
Re: Re: Catalitic converter
I am going to weld a straight pipe in their but before I do that I want to make sure it will sound ok.
Old 03-11-2005, 03:21 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
soak it with pb blaster overnight that usualy works
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 03-12-2005, 03:31 AM
kjewer1 kjewer1 is offline
AF - Advisor
Even a propane torch can help tremendously on rusted bolts. I wouldnt go red hot, but an oxy/acetalene setup would be much faster and more effective. I like to heat it up a bit, whack it a couple times with The Punisher, heat it up, let it cool, etc. The heat cycling and vibration will loosen it eventually. And air tools help tremendously, if they have good power. Otherwise a long breaker bar with the jack handle pipe slid over it will suffice.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-12-2005, 07:58 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Or as a last resort... cut an X in the head of the bolt and twist it off... it worked on some old leaf springs I had to replace years ago!!!
Before I got my "high flow" cat an old neighbor told me to take the cat off and run a broom handle through the screen inside to open it up.
As for the sound... I didn't notice any difference..
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 03-13-2005, 12:31 AM
SSZero's Avatar
Don't worry about the sound, man. It's a DSM, so of course it's gonna sound good...
Stock for now...
Old 03-15-2005, 09:29 AM
K i succefully got the cat off, and then knocked everything out of it, and it sounds the same. I can't just leave it seperate because it is way to loud, so now I found out that the cat wasn't the problem with sound. Where is somewhere I can get a good muffler to replace the stock one, and that will sound good. I wan't something that is a little deeper though, nothing to ricey. Any ideas.
Old 03-15-2005, 10:20 AM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
I would say get a whole exhaust system. that way it will sound awesome, it wont look ricey, and you will have a huge power increase. if you just want cheap, then go buy some 30 dollar thing on ebay, but if you want quality look elsewhere, there are places all over the internet. check out the vfaq
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-15-2005, 04:54 PM
If I remember correctly there is one or two resonators between the cat and muffler... those dampen the sound...
3 words... cat-back-exhaust
