i have a 94 probe that moves until it gets warm. then it wont move at all, stays running but won't move. also when u have a.c on and u turn radio on interior light goes off and the motor revs up a little. the radio goes off if u turn something else on too. is it all electrical or is it tranny too? please help!!!! PLEASE! somebody have any suggestions? i need help desperately.....PLEASE!!!
Re: electrical or tranny?
I am not sure of the problem, but I am having a very simular problem with my 95 SE. My car runs and drives great until it has been driving for about 15 mins, then it starts to shift real hard, and jurk around. Also My Idle somtimes drops to zero and Car Dies. I have heard that it is the trans, but people have also told me it is electical. I tried to do a trans service, but I have the tranny with the filter built in, that you have to rebuild to change it. Let me know if your issues are the same.
Re: Re: electrical or tranny?
I had the same problem but my tranny is still acting wierd but for the other problems you have it not the tranny. Mine was a bad ground wire which should be located beside the drive shaft above you gass pedal i had them same problems and when i checked it out my ground was barely touching so check it out and let me know
did u do anything to ur tranny? to fix it? is my car worth the $ fixing? i need help!!!!
that is exactly what happened to mine and it was the tranny, i got it fixed and it was fine. it could be that computer though, in my 93pgt there is a computer hidden in the dash, u have to take your bezel out(the one with the heat and shit). but make sure u tie a metal wire around your arm and let it dangle to the floor so u dont fry it with the static.
