Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-11-2005, 04:38 AM
Jim Naysium Jim Naysium is offline
Banned
95 Jimmy fuel, electrical problem
My 95 Jimmy wont start. I checked, there's no power to the fuel pump. Back tracking, I find there's no power to the pump relay (in the glove box). I can not find any fuse for the fuel system and dealers are no help. Anyone know where/ how to track for voltage before the relay? If there's no fuses, could there be a fusible link somewhere? I've tried to find wiring diagrams for this but had no results. Thanks
Old 03-11-2005, 03:41 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 95 Jimmy fuel, electrical problem
ECM BAT fuse # 9 20A
Old 03-12-2005, 04:20 PM
rjleee1 rjleee1 is offline
you know Blazert the moderator has a very good point about making sure your battery is fully charged before testing because if your battery isnt FULLY charged your fuel pump cannot get the correct voltage it needs to do its job. If you already haven't done so, charge battery and then test for voltage. By the way the fuel pump on the 95 Jimmy is in the gas tank I believe. Good luck .you can do an ohms test on the relay sorry I couldn't be more help on wiring
Old 03-13-2005, 04:51 PM
red97 red97 is offline
dont know if this will help. 97 jimmy half elec dead. fuel pump, door locks, trans unlock out of park, turn signals? this forum told me it was a wire harness connecting the key tumbler to the car. go buy a good book on the truck.
