Old 03-11-2005, 05:36 AM
deathshead deathshead is offline
fuse block???????
hey everyone im new to car stereos and im wondering what a fuse block is for????? im running 2 audiobahn dub 1000's at 2ohm with an audiobahn 8002t amp with a 2.2 farad cap in a fibergalss enclosure but im being told i need a fuse block but i dont know what they are for or why i need 1 can someone plese help me out
Old 03-11-2005, 01:32 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: fuse block???????
You need a fuse block about a foot from the battery this is in case your amp shorts and doesnt go into protect or you drw to much current on the wire you dont fry the cars electronics. You can also put one inline with the cap but its not needed. I see kids wire amps up with out fuse blocks and they dont think they need it, i also see kids put 2 different size subs on a 2 channel it overheats in about 10 min.
Old 03-11-2005, 01:46 PM
germanyt germanyt is offline
id say a 60 to 70 amp fuse block should suffice. dont go to high though, you dont want the fuse to allow more current than the amp can handle. obviously that would defeat the purpose.
Old 03-11-2005, 01:49 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
or u can learn what your talking about. There are fuses and fuse holders, an there are fuse distribution blocks. Either way, you dont NEED either of them. Inline fuses like ^ stated are not necessary if you have fuses already on your amp which your amp does so you got nothin to worry about.
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 03-11-2005, 02:50 PM
in all my life i have never seen a system that didnt have a fuse within 12 inches of the battery. true, your amp fuses are designed to protect it. but it doesn't hurt to be safe. should something happen and your amp fuses short, there is a possibility it could arc and fry the amp. is it likely to happen? NO. but like i said it doesn't hurt to be safe.
Old 03-11-2005, 08:45 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
guys, a fuse BLOCK is a bank of fuses - often times combined with a distribution block. It goes in as say a 2 guage, is routed to 3 or 4 fuse holders, and comes out as 3 or 4 say 6 or 8 Ga wires to power 3 or 4 amps.
Old 03-12-2005, 12:35 AM
thats right. its and inline fuse not a fuse block. i stand corrected.
