Old 03-10-2005, 07:53 PM
BlazinUP BlazinUP is offline
bad torque convertor? how to tell?
anyone know the tell tail signs of a dying torque converter?
Old 03-17-2005, 01:23 PM
crazycory1 crazycory1 is offline
Its hard to tell between a bad torque converter and a bad trans. If your trans fuild is clean and doesn't smell burnt take your truck to a trans shop. They will have the tools to check the pressure of the trans fuild that is made by the torque converter.
Old 03-17-2005, 03:16 PM
smokey041369 smokey041369 is offline
Re: bad torque convertor? how to tell
the torq converter turns two shafts that go into the front of tranny and make the fluid pump work.
haven't heard of a torq converter going bad, remove the bottom tranny line from the radiator,start the truck no fluid the pump is bad and probly burned up the tranny, if fluid comes out then have the tranny checked
Old 03-17-2005, 04:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: bad torque convertor? how to tell?
What problems are you seeing?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-17-2005, 10:24 PM
my 93 s10 4.3 cpi has 148k....
runs...perfect.......except.
when i floor the gas....i hear the sound of an engine at wide open throttle...but i dont get the power.......not quite a slipping..like a bad clutch.
there is still pulling..just not like normal.
almost like something is holding back the power
if i didnt nail the gas youd never suspect a problem...the trans goes threw the gears fine....holds speed in every gear.......just this problem...at w.o.t.
no strange noises either....
btw ..the fluid is at the right level....and the filter is new ...was replaced about 3 k miles ago.
Old 03-18-2005, 02:52 AM
BlazerLT's Avatar
AF -Advisor
Is it downshifting when you floor it?
Old 03-18-2005, 09:36 PM
yes it downshifts....and the engine sounds purrfict.......like normal.....
xcept the power feels restrained.
at times it feels almost like a bad clutch would feel (slipping wise)
other times it feels like its slipping..then bamm....the power comes back.
Old 03-18-2005, 09:56 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: bad torque convertor? how to tell
Tuneup lately?
Old 03-18-2005, 10:09 PM
yea....plugs/wires/fuel filter/tranny filter&fluid/
front rear diff fluid/air intake is rather new/
pcv valve/breather/cleaned egr/
the only thing i havent changed..is the cap and rotor....
but it doesnt feel like an engine problem.
im prob about to buy a ticket to rebuilt tranny ville
Old 03-18-2005, 10:28 PM
BlazerLT's Avatar
AF -Advisor
How old is the cap and rotor?
Old 03-19-2005, 07:13 AM
the mechanic told me that was the only thing that looked like it was fine.........
im the second owner.......
Old 03-19-2005, 10:41 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
could have a bad clutch pack, would make it not enguage correctly, like a clutch not enguageing
Old 03-19-2005, 01:34 PM
BlazerLT's Avatar
AF -Advisor
REplace the cap and rotor first.
It has to be changed.
Old 03-19-2005, 07:17 PM
because you think thats causing my problem...?
or because you think it needs to be changed?
do you believe a bad cap or rotor would cause this type of problem........even after iv said the engine itself.....revs and sounds perfect....starts...idles...etc......
Old 03-19-2005, 07:18 PM
clutch pack....what and where is that....never heard of that before.
