Old 03-10-2005, 07:22 PM
PMPlumber PMPlumber is offline
Front rotor warpage
My 99 K1500 ext cab ( 98 body style ) is warping front rotors about every 20,000 mi. . The truck is stock, I have checked the rear brake and adjusted them, checked the calipers they are floating on the pins and release as they should. Recently I changed the master cylinder, this improved the feel of the brake pedal but the rotors need replacing again. I have not had this problem with any other vehicle so any help would be appreciated.
Old 03-10-2005, 08:38 PM
2000CAYukon 2000CAYukon is offline
Re: Front rotor warpage
How much drag are setting on the rears? If the emergency brake pedal goes too far, the rears are not tight enough.
You should feel some drag when you turn the wheel or drum.
//2000CAYukon
Old 03-10-2005, 08:59 PM
amac209 amac209 is offline
Send a message via MSN to amac209
was this truck ever in an accident? you might have a bent hub or loose wheel bearing.
Old 03-10-2005, 09:19 PM
bad68chev bad68chev is offline
Re: Re: Front rotor warpage
Are you using factory pads? Some aftermarket pads have the wrong hardness and can cause rotors to heat excessively. Also you may want to check for Technical Service Bulletins from GM, I think there is one for 92-99 trucks. Check clearance between caliper and Spindle, if clearance is not correct may have to file some off spindle to make correct clearance. I think the TSB also mentioned something about replacing a valve (proportioning valve I think). Does the vehicle pull when braking?
I replaced my factory rotors with cross drilled and slotted ones from R1 concepts in California, cost was $99 plus $15 to ship to AZ, Suburban stops way better plus the rotors are supposed to stay about 250 degrees cooler which will prevent warping.
Old 03-10-2005, 09:20 PM
//2000CAYukon
The emergency brake pedal does not travel far at all and the rear brake are set so that they have a slight resistance when spun by hand.
Old 03-10-2005, 09:28 PM
Re: Re: Re: Front rotor warpage
The pads are NAPA premium semi metallic, and the truck does not pull to one side or another. I will have to look into the service bulletins , thanks.
Old 03-10-2005, 09:36 PM
The truck was a dealer demo unit so I would doubt it was in an accident but it was probably not treated with tlc the first 20,000 mi. . I have checked the spindle or wheelbearing assembly and that checks out fine.
Old 03-10-2005, 10:44 PM
J-Ri's Avatar
J-Ri J-Ri is offline
You said that the brake pedal is firmer now... could it be that you might be pressing too hard now?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-15-2005, 07:30 PM
The problem started before the master cylinder was replaced
Old 03-15-2005, 07:39 PM
I have been unable to locate any service bulletins from GM regarding this type of probem online. Is this something that only dealers have available?
Old 03-16-2005, 08:32 AM
nicemunkie nicemunkie is offline
I have a '97 K1500 and it does the same damn thing. Mine only warps the right side though. It's starting to shake again and the brakes were all done just over a year ago.
Old 03-16-2005, 06:45 PM
gremlin96 gremlin96 is offline
check and see if your calper is floating. the pins tend to rust and that will stop your calper from returning to center when the brake is let up.
also check the spendal for ware. if you see a spot ware its been rubed the bearings will not seat right.
clean the calper and lube it. when you replace the rotor change all the bearings. saves you headacks later.
