Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 03-25-2002, 04:02 PM
redvalkrie's Avatar
redvalkrie redvalkrie is offline
Send a message via Yahoo to redvalkrie
Wink Need some Help with Fuel Filter Change!
Ok I have looked over & under the car were is the "F"ing fuel filter is it disguised as another part or is it in the fuel tank or under the rear seat, peak boo I don't "F" see you!
Some help will be greatly appreciated!
Thanks People!
By the way I am back after 6months of not seeing you all!
Primera were are you MAN!
(I hear what you are saying but I feel you are lieing to me, would love to say to BUSH!)
"Don't trip, skip, pinch your forehead"!
1988 CRX Si
2001 CBR 600F4i Silver & black FAST!
2004 Toyota Tundra (TRD)
2002 dodge grand caravan.
Old 03-26-2002, 09:40 AM
NismoPC's Avatar
NismoPC NismoPC is offline
I would assume it is in the same location as all other SR20's. The fuel filter is a canister approx. 3" in diameter and 4" long with connectors on each end about 1' in length. It is located to the left of the power steering and master brake cylinder against the fire wall.
Don't have any pics to show. Do you have any manuals (FSM, Haynes, Chiltons, etc.) that are SR20DE powered cars? If not, go check one out at the auto parts store. Flip through it and find a pic.
Hope that helps!
Brandon
'96 G20 - modified
Old 03-26-2002, 09:59 AM
redvalkrie's Avatar
Hey thanks bud, unfortunetly on the 99 there are some parts that are in odd places so when I checked a 99 versus the 2000 that I have the fuel filter is not there or they have made it look diffrent.
Thanks for your help will check the manuals.
1988 CRX Si
Old 03-26-2002, 10:02 AM
NismoPC's Avatar
No prob! Now I am curiuos to where it is located. When you find out let us know, will ya!
Brandon
'96 G20 - modified
Old 04-01-2002, 08:47 AM
ronnie_g's Avatar
ronnie_g ronnie_g is offline
I just want to remind you folks to release the gas pressure by removing the fuse for fuel pump, then start the car until it dies. Just want to share this safety precautions. I still need to find where the fuse is located because I also wanted to change my fuel filter.
94'G20t / UR Ultra S pulley / JWT Pop charger .....
Sony ES Head/Boston Acoustic Pro Series 6.4/ Cerwin Vega 6002/
MTX 3x10's/ Monster Cap
Sony XE-90MkII EQ/ SonyCDX715
CD Changer/Nakamichi EC-302
Mobile 3-Way Electronic X-over
Amps: Fosgate Punch 600w A4/ Kenwood PS300/JBL GTQ360
Protection: G19 15+1 Cor Bon +P 115 GR JHP/Bali
:jump: :badass:
Old 04-25-2004, 04:31 PM
GT1 GT1 is offline
Can't find fuel pump fuse
I want to change the fuel filter on a 99 G20, and see the filter next to the firewall on the driver side, but can't find the fuel pump fuse. It is not in the fuse box next to the battery or in the relay box by the windshield fluid filler. Can someone please tell me where the fuel pump fuse is located so I can change out the fuel filter? Thanks.
Old 08-20-2004, 09:19 AM
elkinm elkinm is offline
I am not sure how to explain it without pictures so I will try to direct you.
From the front of the car go to the left side of the car (passenger side), also the side of the engine with the belts and plies.
Now you are looking at the engine block, look to the left of it, or cabin side close to belts and plies.
There will be a gap right there just left of the block where you would see a rounded of cylinder sticking out about 3' diameter and sticking out about 3' or so.
My manual says that that is the filter and it looks right from new filters I have seen but I have never changed it myself. I don't know how to change it as I don't se how I can get to it to unscrew it.
