Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 03-10-2005, 06:50 PM
dmcline dmcline is offline
Lightbulb Advise
Advise please. I already have greasable sway bar bushings for the rear on my 2002 Xterra. I am looking for the same thing for the front. Also, any advise on using Synthetic Oil in the axles? The dealer told me it was not recommended.
Old 03-10-2005, 07:53 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: Advise
Why would you want greaseable bushings? I'm not aware of any problem with them, they're about $2 each to replace if they ever wear out.
Synthetic oil is a VERY good idea in the diffs, your dealer was blowing smoke. 80W90 limited-slip-compatible GL5 oil is what you need.
Brent
Old 03-10-2005, 08:09 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Re: Re: Advise
Brent
They seem to wear out about 1000 miles after they're put in. The Nissan ones suck and will have a wear through point quite quickly, but I just keep 'em lubed whenever I'm pulling them apart.
The greasable Energy brackets don't hold up well at all up front. Here's the part number for urethane bushings which should at least last longer. Use the stock brackets.
Energy front sway center bushing: 9.5162
Xterra4x4.com and the Xterra Offroad Webring
Old 03-10-2005, 08:57 PM
Re: Re: Re: Advise
9.5162 are showing greasable on the energy suspension site. Do you have a link where I can find the ones you are talking about? Also, what do you think about putting a steering stabilizer on my truck? Thanks a lot.
Old 03-10-2005, 10:34 PM
chubbybubba1 chubbybubba1 is offline
Re: Advise
Royal Purple makes a syn axle oil that is LSD compatible. Napa carries or can order It.
Old 03-10-2005, 11:21 PM
XTerra Guy
Re: Re: Re: Re: Advise
Yes, the bracket is greasable, but it's tin-foil, thus using the stock bracke. Me, personally I don't like steering stabilizers because I feel they hide suspension/steering problems from the driver. With a lift I need to know if anything is going goofy.
Old 03-11-2005, 08:54 AM
Re: Re: Re: Advise
Hmm, mine lasted about 4 years up until I took the swaybar off for good. They were certainly ragged and in poor shape, but not completely shot.
Old 03-11-2005, 12:52 PM
XTerra Guy
Maybe because you don't have a lift. The extra angle on the swaybar probably puts more pressure on the bushing. Worn through to metal bushings are pretty common in our club.
