Old 03-10-2005, 06:23 PM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
Engine wear?
newbie here. have a 97 black blazer LS with 148k miles. i noticed BlazerLT posted in a topic that running the defrost a lot will wear on your engine and wastes fuel. how much of a difference will it make by leaving it off? i guess living in michigan i didnt think much of leavin it on when im drivin around during the winter.. even if i dont need the heat, just leaving it on the windows. just a little tidbit i thought u guys could help me with. oh yea, just for an added note.. i jus had a heater core replaced and they are a bitch. im not sure how to do those, so i had it done by a trust auto shop and it was still $500. thanks
Old 03-10-2005, 06:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Engine wear?
It can really hurt your economy because you are constantly running the AC compressor which puts more load on the engine.
Use only when needed and use the floor option any other time. Don't use blend.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-11-2005, 08:25 AM
metallica21156's Avatar
metallica21156 metallica21156 is offline
Re: Engine wear?
as soon as you go below 40 F the AC compressor will not turn on. i read it some where and mine won't turn on if its that cold. so really your fine if its below that. any higher then 40 and it will run.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 03-11-2005, 03:02 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Engine wear?
Defrost will turn the AC compressor on to dehumidify the air. Doesn't matter what temperature.
Old 03-12-2005, 02:16 PM
Re: Engine wear?
blazerLT. i'm telling you its true. next time its below 40 or snowing. turn your defrost on and open the hood. you will see the AC doesn't run. also you will notice that the RPMs don't bounce up and down when the compressor kicks in. the only time it might drop is when you turn the switch. if you don't bealeave me go out and look. if yours does work then maybe its time to have mine looked at.
Old 03-12-2005, 03:38 PM
tom3 tom3 is offline
Re: Engine wear?
These run off a pressure switch. At low temps the pressures are pretty low and the compressor will cycle some, runs very little. Could be a temp switch on the new stuff, everything is more complicated on them, more to go wrong. General theory is that the compressor needs to run now and then to keep the seals lubed anyway.
Old 03-13-2005, 12:13 AM
BlazerLT's Avatar
AF -Advisor
Just did it, and yip, mine runs.
Old 03-13-2005, 08:42 AM
Re: Engine wear?
and it was below 40? i might have low pressure then.
Old 03-13-2005, 09:05 AM
JParrott's Avatar
JParrott JParrott is offline
It has to be something along those lines of low pressure because I run mine on blend almost every day when I start my Blazer up in the morning and let it run for 4-6 minutes, and my compressor cycles almost instantly. Temps here are in the teens every morning. I had my system recharged this last summer. However, I disagree with the engine wear theory. A part of the compressor cycling is to dehumidify the air, but I've also been taught that it's to keep the lines and seals lubed and in good condition when temps are too cool for people to run the A/C a normal amount of time. I don't believe that running it promotes engine wear any more than normal. It will definently increase gas usage and promote poor mileage but not engine wear.
Old 03-13-2005, 02:25 PM
BlazerLT's Avatar
AF -Advisor
Listen, just stop questioning this would ya, I am getting a little tired of it.
The AC uses the friggin AC compressor to dehumidify the air when using defrost and that is FINAL.
Old 03-13-2005, 02:30 PM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
Re: Engine wear?
Why use a/c when you don't need it? Wastes a lot of extra money on gas and you don't need it in the winter except to defog the windows. Using the compressor too much will definately wear it out quicker. just my 2 cents
Old 03-13-2005, 02:48 PM
BlazerLT's Avatar
AF -Advisor
Very true. Use defrost or blend until the windows are clear and then switch it to vent or floor to save money.
