Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-10-2005, 04:17 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Bought new ignition wires.
Seeing mine are stock, I decided to purchase a set of Autolite wires for my 1995 4.3L.
For my year it is vERY hard to find them here in Canada and the dealer wants close to US$60 for a set.
I bought the set off of ebay for US$20 which included shipping.
I'll let you know how it turns out.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-10-2005, 04:24 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Bought new ignition wires.
Yes, please do! Mine are a bit worn and fuzzy feeling around the jacket already, and they were just replaced. I cringe to think of paying Dealership prices, but even $30 OEM-style replacements have left me with a foul after-taste. :P
Old 03-15-2005, 11:02 AM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
I am more interested in if you follow the one repair manual your own (not sure if it's Haynes or Chilton) that shows the number 1 plug on drivers side middle.
Let us know how it turns out......
1999 Blazer LS 4WD 4.3L "W"
2004 Silverado 2500HD Duramax
Old 03-15-2005, 11:13 AM
BlazerLT's Avatar
AF -Advisor
Keep up the attitude, I DARE YA!
I don't use a repair manual to change plug wires, I swap wire for wire.
And again, keep up the snide, smartass remarks and you will have a vacation for a while.
Old 03-15-2005, 06:58 PM
Turbocpe Turbocpe is offline
Not sure I understand the comment, but on my '98, the #1 spark plug wire attaches to the driver's side of the distributor cap, the one in the middle. That number 1 is the only one that is out of sequence on the distributor cap.
Maybe the '95 is different and I'm confused.
I've owned Haynes and Chilton manuals, and I honestly have to say, the mistakes and lack of information makes them very questionable. I'd never use them again. The factory shop manuals are the best, but of course, come at a price.
Old 03-15-2005, 09:51 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Bought new ignition wires.
Just swapped in the new wires today. And yes, you are right. The middle driver's connection on the cap goes to the driver's side front cylinder.
The wire swap was a PAIN in the ASS! Rerouting them and trying to get your hands back to the cap to connect the wires was a complete bitch.
Did I need to install new wires, well, yes and no.
The one thing I did find was that the coil wire was corroded VERY badly on the coil itself, but the connection to the cap was clean. I could have done just that wire and kept everything else stock. The corrosion was terrible, and the coil electrode was completely encrusted with white crap and I have no clue how voltage was getting through it. Borderline miracle. I had to sand the corrosion off and even then the electrode was pitted badly.
The 1995 stock wires were in perfect condition, no cracks, breaks, chaffing or any damage at all other than the one connection on the coil wire.
Although the autolite wires were pregreased, I added more grease to the boots and they installed pretty well other than the clips and routing.
So to all thinking they need new wires, you might want to save you money and just check the wires one by one.
The truck ran a little rough for the first two minutes or so but that was to be expected seeing I had removed the battery for charging while I was doing the swap.
Now everything is back together and the truck does seem to have lost any bog it had at all. The corrosion was probably signifcantly hindering the voltage going to the cap and rotor, and this could be the reason why my fuel economy has gone down a bit lately.
Old 03-15-2005, 10:32 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
just for referenceall 4.3's are the following...
6 5
4 3
2 1
X
And if you look at the cap, it really does bring the #1 wire to the 7 o'clock position via the design of the cap. Same place where it is on a normal cap. (ie. normal being top post mounted) The firing order is still 165432 just that the design of the side post mount distributor caps make it look funky. they're still the following
4
5 3
6 2
1
Old 09-12-2005, 12:09 AM
BlazerLT's Avatar
AF -Advisor
Ok, update.....
AVOID AUTOLITE WIRES!
Just changed my cap and rotor and those new wires ripped the condictor out of the boot on two of the wires connecting to the cap.
PLUS, one ripped out when I was regreasing the plug ends as well.
These are made REALLY cheap and you can tell when you look inside the connections.
AVOID!!! My 10 year old wires are more durable that this.
Old 09-12-2005, 12:23 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
wow, perfect post, at a perfect time. I was just considering doing this with a 1995 Jimmy. The fool at autozone quoted me 50 bux for a set of ac-delco plug wires and 8 bux for ac plat plugs, and he said that the autolite wires and plugs would be just fine and cost considerably less. Thank you so much for saving me the headaches BlazerLT.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-12-2005, 01:07 AM
BlazerLT's Avatar
AF -Advisor
Stick to ac delco wires and delco platinum plugs bro....
Trust me, these things are absolute shit.
Old 09-12-2005, 01:12 AM
Jeremy Fitch Jeremy Fitch is offline
Send a message via Yahoo to Jeremy Fitch
Amen, been there tried those. My boots pulled off mine real easy too. I founf that even the Xact advance brand are better and cheaper than autolite at around 29.00. ADvance wants over 90.00 for a set of AC Delco.
Old 09-12-2005, 03:53 AM
BlazerLT's Avatar
AF -Advisor
They are worth it, mine lasted 10 years and I replaced the broken wires with the stock ones I still have from 1995 that I just swapped off.
They installed just fine.
Old 09-12-2005, 04:21 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
This is a great post! There is always a lot of confusion on what brand of wires to buy. On a personal side a couple of years ago I was changing the wires on my S10 p/u cause a couple had cracked and started arcing. I figured I'd go with the Autobone cheepos. Well, guess what - the truck ran like shit. I had a trustworthy mechanic look at it and he said he misted the wires w/water and could see arcs all over the place. I took the wires back and they gave me another set. Had the same problem with these! I finally said screw it - through them at the guy- got my $$ back and went to Advance. They got me another set (can't remember which brand) which caost me almost double and the worked like champs!! I could even feel the difference in the casing. Just goes to show that you really do get what you pay for...
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
I don't think mine really even needed changed, I couldn't tell any difference when I changed them. I kept the old ones just in case I needed an extra one or two, but so far so good with the cheapo Advance brand.
Old 09-12-2005, 06:11 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Bought new ignition wires.
Just wait until you have 20k on them and they tear the plug connector out of them. My god was I pissed off.
Here I am trying to do something good and change the cap and rotor and I end up screwing something else up.
Closed Thread
