0-60 1/14 mile time
i have a 2001 Silverado extended cab short bed 4x4 with a k&n high flow air filter and a flowmater american thunder exhaust system. My horsepower is now about 320 and my torque is now about 400 out of my 6.0l with the mods. Can anyone tell me what my 0-60 and 1/4 mile time is?
Re: 0-60 1/14 mile time
Anyways, there's only one way to really find out what your 1/4 time is, and that's take it to a track. I honestly don't even know what a 3/4 ton truck will run in the 1/4, but it would be slower then a 1/2 ton with the 5.3, and they typically go 15.7-16.0 (according to other people anywyas, I've never seen one run). So if I was guessing, I'd say you'd be somewhere in the mid to low 16 second range, but I really have no idea.
**1966 Chevy II** ![]() 355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4 Last Race (10-6-07) So its been awhile... Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph Fastest Pass of '07 (10-6-07) 60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph 25 and in BIG TIME Debt Crew member #2 Deuce's Wild Racing: Take a Ride on the WILD SIDE
i started with 300 horsepower and 370 lbs. of torque, the 2500hd silverados have 360 lbs. of toque probably due to the more powerful alternator
The alternator does not have a single thing to do with the hp & tq output of your engine.
**2007 Avalanche LT. ** ![]() 6" Pro Comp lift 305/55/20 BFG A/T KO'S K&N FIPK GENII Flo Pro V force muffler & 4" slash cut stainless tips Color matched front and rear Bowties 3" polished stainless bull bar and Nerf bars |
Re: Re: 0-60 1/14 mile time
Either way, even if you did have 370 lbs-tq, the drop in filter and exhaust wouldn't give you 30 lbs-tq. I'm not trying to be a smart ass towards you, I'm just saying don't believe these aftermarket companies when they claim 15-20 hp from a drop in filter, and 15-20 hp from an exhaust system. And surely don't add them up becuase you have both mods. A drop in filter, along with a bigger throttle body, full exhaust (including headers and cats) only gives an LS1 a little over 30 or so rwhp, and that's with a manual transmission. Basically, your drop in filter might have given you 5 hp, and your exhaust might have given you 5-8 hp. And actually, the alternator or any accessory item would effect the horsepower of an engine, however that's already accounted for when the factory rates them. That's why you never see drag cars with alternators, manual water pumps, manual fans, power steering, etc.
Standing in line at the auto parts store today, I saw a segment on the in-store network that said even the best air filters (I assumed K&N, but maybe some other brand) will only add 3-5 hp. And that's if the engine can barely breathe stock.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
Re: Re: Re: 0-60 1/14 mile time
That is pretty much what i meant, a larger alternator or any other larger/ more powerful acessory that you install in place of a factory one will not make any differnece.
Re: Re: Re: Re: 0-60 1/14 mile time
ok, so even if i didnt gain what i thought i did, the question was what is my 0-60 and 1/4 mile time.
