Old 03-10-2005, 03:52 PM
fischnet fischnet is offline
Multi Function Switch
Does anyone know were the Multi Function Switch is on a 1998 S-10 Blazer? And How hard it is to replace it?
My signal flasher is clicking all the time and my mechanic said it is the multi function switch not the flasher. $460.00 to replace. any help would be wonderful.
Old 03-10-2005, 07:16 PM
zr2rando zr2rando is offline
I think the switch he is talking about is the lever sticking out the left side of the steering column..the blinker lever (has the windshield wipers/washer/cruise etc). Shouldn't be $460?. Sounds like he thinks there is a short in it that makes the blinker permanently "on". Somebody else can probably tell you more about cost/job difficulty, Good luck with less cost than he said.
Old 03-11-2005, 05:47 PM
Cam1959 Cam1959 is offline
Re: Multi Function Switch
i'd start by putting good quality flasher in there.
if still prob, i'd try cleaning or replacing turn signal switch.
seems to be power getting to flasher when it shouldn't, suggesting faulty turn switch.
Old 03-11-2005, 07:44 PM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: Re: Multi Function Switch
No thats the right price. there VERY EXPENSIVE! Those suck to do also, Check your relays, flashers, and around the steering column for loose wires. Also Generally if the switch still locks down when you hit your turn signals. its still a good switch. Other wize dude take it 2 a pro its not a fun job. gotta take the steering wheel off. and everything. Lots of tools and lots of hours. Which signal is going all the time? well
Old 03-24-2005, 10:50 AM
Allbert Allbert is offline
There's a ton of posts on this subject over in the Blazer forum. Some people have claimed just cleaning the contacts in the MFS will cure the problem.
Old 03-24-2005, 01:28 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Multi Function Swtich
Replace the flasher first just to make sure.
The flasher is 4 bucks.
1995 Factory Blazer Service Manual for sale, PM if interested.
