Old 03-10-2005, 03:24 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Oil level?
Today on the drive home from school the shifting was partiucularly bad across the board. I checked the oil gauge and it was in the middle as normal, but when I came to a stop it dropped to the low position (1/3 the way up). So when I got home I checked the dip stick (3 times) and it was high (just after the second notch but before the twist). Wtf is wrong? Does the oil gauge measure the engine oil or the tranny oil or what? How can I check the transmission oil? Ohh and I looked under the car and there didn't seem to be any leaking. What is involved in changing the transmission oil (if its different from the regular oil), and what kind would I need?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 03-10-2005, 04:13 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Oil level?
ya, the oil gauge on your car measures only the engine oil. trans oil, i don't think, can be measured. however, since you just got your car, you might as well change the tranny oil. we've posted a few times, Igovert and I, that we both use Pennzoil Synchromesh MTX fluid. i got mine at www.midwayautosupply.com b/c not many stores down here in TX carry it.
as for changing the fluid, 316 has some good illustrated info on it: http://www.stealth316.com/2-awddrainfill.htm
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-10-2005, 04:28 PM
Thourun's Avatar
Re: Oil level?
Yea I want to change it, but what would cause my gauge to read low other than the gauge being broken, I went out to move the car so I could use my moms and it was still all warmed up from driving home and it read two notches from the low line... not good. Dipstick still reads fuller than full.
1995 3000GT VR-4
Old 03-10-2005, 04:53 PM
PoorLuder PoorLuder is offline
Perhaps we should clarify by saying that it is reading the pressure of the oil in the engine although you probably already know that. That pressure will fluctuate as you drive because you are constantly changing the pressure in the engine. I would not be looking at your oil gauge as the source of your problem. Do a tranny flush and then see if you still have bad shifting. Having engine oil above the full position on your dipstick is fine (as long as it is not excessive), what you need to worry about is having the correct amount of tranny fluid since your tranny is much more pressure sensitive.
95 Stealth
http://www.cardomain.com/id/stealthsohcer
Old 03-10-2005, 05:47 PM
Igovert500's Avatar
blue + red light magnet
Re: Oil level?
Yeah, the pressure gauge fluctuates with quite a few things, temperature, how hard your driving, rpms, etc...and just like our boost gauge it isn't always all that accurate. But those levels you are describing sound pretty normal. If anything, you might have a bit too much oil in there is it is above the 2nd line...the 2nd line is about where it should be.
Also the 2nd link Linbckr gave is all you need to know about tranny oil in a vr4. If you have everything you need and don't have to make a multiple trips 2 autozone in your mom's car (yeah it sucked) you can knock it out in an hour or 2.
I just put the car up on 2 jackstands, 1 3 ton jack, and 3 scissor emergency jacks from various cars, printed out the pictures from stealth316, bought fluids and pumps and torque wrench, and went at it.
I found I had trouble with getting access to the t-case plugs, so you may have to remove your downpipe to do this....and if you do that...they why not just gut the precats...see it can be one productive Saturday afternoon
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-10-2005, 06:40 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Oil level?
As far as checking the oil level accurately...I had to pull the dipstick out and wipe it off 5-6 times before it was where it was actually at (which was none at all!). I think the tube just holds a lot of fluid on the walls so you have to keep wiping it off untill there's no fluid above, and there's just a solid line where it stops.
Old 03-10-2005, 08:00 PM
Thourun's Avatar
Re: Oil level?
There was a pretty solid line and to check to see if it was just oil in the tube I stuck it in allmost all teh way down and pulled it out and there wasn't any on it. I did notice that there was an orangish deposit on the oil cap.
I read a big long thread on the synchromesh stuff on 3SI and seems that people have had mixed results, some say its because it wasn't made for our cars and is too light. I'm going ot check out royal purple.
1995 3000GT VR-4
Old 03-10-2005, 10:02 PM
Thourun's Avatar
Re: Oil level?
Ok well I did some reading on the synchromesh over at 3SI, seems like a LOT of people hate it. There dosent seem to be ANY consensus on what one should use in the tranny and transfer case though... WTF should I use!
Edit: After doing some more reading I'm leaning more towards Royal Purple. Has anyone else done all the reading up on what works and what dosent? I want much smoother like the pen Synchromesh seems to give but withought the wear and tear and frequent oil changes that seem to be associated with it. Anyone use the Purple?
1995 3000GT VR-4
Old 03-10-2005, 10:28 PM
sLADe781 sLADe781 is offline
Re: Re: Oil level?
Wait, what wear and tear due to Synchromesh? Hehe Because I'm gonna do mine over the summer and don't want anything wearing and especially not tearing.... No seriously, what bad stuff did you hear about it?
Old 03-10-2005, 10:54 PM
Thourun's Avatar
Re: Oil level?
I'll go find the big thread about it.
http://www.3si.org/forum/showthread....ht=synchromesh
http://www.3si.org/forum/showthread.php?t=254510
1995 3000GT VR-4
Old 03-11-2005, 02:04 AM
Re: Oil level?
Damn! Well Thourun, I'm just as stumped as you are. Anyone here wanna say anything about the matter? I know a couple of you guys are using Synchromesh....have you drained it and checked to see how it looks and so forth?
