front-end noise
my 02 venture ls with 42k is making a very annoying noise upon startup and up to 10 minutes afterwards. the noise is best described as a buzz/rattle. is seems to be coming from under the front end, under the radiator. it gets louder as the engine is reved and goes away upon warmup. the dealer has attempted to fix it 4 times now. they have tightened all heat shields. does anyone have any ideas?
Re: front-end noise
Re: front-end noise
I had a problem like that on my '99. It turns out the prop rod for the hood was not tied down properly. The plastic clip was partially broken, and caused the rod to vibrate against the frame. A few dollars later, no more buzz. But, my problem was more constant than yours appears to be.
Chek air pomp houses for water inside.
Re: front-end noise
where are the air PUMP hoses??? |
