Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-10-2005, 01:26 PM
mikew1 mikew1 is offline
91 caprice water pump
My water pump is shot. I let it go as long as i could sounded like a washing machine. It is now spraying liquid all over the place at least i couldn't find any leaks anywhere else. The fan is spraying anti-freeze all over. It is not a flood though. Will the pump leak like that? Is this a tough job to replace? Should I also replace the clutch fan? How can I test for that Just spin it by hand? Any tips on the install will be greatly appreciated. Thanks
Old 03-10-2005, 09:30 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: 91 caprice water pump
The water pump is is a fairly easy thing to replace. Jus loosen, or take off the belt, take off the fan, the there are 3 bolts that hold on the pump. Then you're good ta go.
Old 06-24-2005, 08:57 PM
getfreshco getfreshco is offline
yeah
water pump is fairly easy to replace........when i replaced mine on my 91 caprice i also replace all the hoses in the cooling system
