1991 intermittent starting problems
This question is about a 1991 Bravada 4.3 since it's very similar to a
Blazer. When I need it to start at critical times, I can never be sure that it will. It cranks OK. I've replaced all of the ignition parts that should affect starting. At the times it won't start, if I leave it alone for 20 minutes or so, it fires right up!! During cranking, the injectors are firing OK. Also, starting fluid does no good. No codes are being set. I put in a new coolant sensor (the one the commper reads). I would certainly appreciate any other ways to diagnose this problem. Also, does the computer read the throttle position sensor at cold startup (warm startup too)? |
Re: 1991 intermittent starting problems
What ignition parts did you replace?
Did you check the battery voltage? Ever replaced the fuel filter? Ever check the timing with the timing wire unattached?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Replaced the ign module, pickup assy, dist rotor and cap along with ign coil. Replaced fuel filter. Batt voltage checks ok along with timing (wire not attached). Thanks for your time on the message. Any other things I might check will be appreciated.
Regards. |
Re: Re: 1991 intermittent starting problems
The battery voltage is 12.92v. Regards
I'll acquire a gauge and get back to you
