Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 03-10-2005, 10:14 AM
BigWilly01 BigWilly01 is offline
01 corolla LE
ok guys.. I have a 2001 Toyota Corolla LE
my car idles low when starting, hesitates when accelerating and when I start it during cold weather sometimes it stalls 1 or 2 times before it finally gets going..
I have changed the spark plugs, cleaned the intake manifold, changed air filter, had the mechanics at toyota look at all the sensors related to intake and exhaust (O2 sensor, MAF sensors). I still can't find the problem, other than speculating that it is my performance exhaust. However, many other corollas in my carclub has performance exhaust (non-TRD) and their car does not idle weird like mine.
I have changed my oil regularly every 5000 KM and I use mobil 1 full synthetic.. maintainance has been done according to service plan (except for oil changes are done more frequently instead of suggested 6 months or 8000 km) .. oh btw.. the engine has 62500 KM on it.. it's still VERY young.
Please help me with this problem .. it's only getting worse.
Old 03-14-2005, 12:41 AM
Re: 01 corolla LE
I am part of corollacustomz.com, northeasterntuners.com, toyota-nation.com etc etc.. I've laready asked help from there and no one has responded or rather solved the problem.
Old 03-14-2005, 12:50 AM
asn13oy asn13oy is offline
Re: 01 corolla LE
Have you tried sea foam?
Old 03-14-2005, 12:51 AM
Re: 01 corolla LE
nope not at the moment.. I tried putting fuel injector cleaner.. haven't ran w/o it for about 5 k kms now.. maybe it'll help?
*edit* type o
Old 03-14-2005, 12:55 AM
Re: 01 corolla LE
How are your battery contacts?
Re: 01 corolla LE
battery contacts are a bit dirty.. they were corroded.. but I cleaned them off and made sure that my engine grounds are ok
Old 03-14-2005, 12:57 AM
Re: 01 corolla LE
Possibility of a vacuum leak
Old 03-14-2005, 12:59 AM
Re: 01 corolla LE
all I can think of then, is the vacuum, or fuel injection.
Re: 01 corolla LE
can it be a clogged fuel filter or bad fuel pump?
Old 03-14-2005, 01:00 AM
Re: 01 corolla LE
I hope it's not the fuel filter, b/c you'd have to service/replace the entire fuel pump then.
Old 03-14-2005, 01:03 AM
Re: 01 corolla LE
yup I know.. it could even be a weak ignition coil.. it seems to start better tonite when I cranked it.. but the prior time it stalled 4 times before starting up
Old 03-14-2005, 01:08 AM
Re: 01 corolla LE
I'd say throw in the whole lot of fuel injector cleaners, Sea foam, etc. and see how many people you can piss off in your neighborhood, as drive around leaving plumes of smoke.
Old 03-14-2005, 01:11 AM
Re: Re: 01 corolla LE
haha my car doesn't smoke right now. it's only a starting up problem.. I've checked all the routine things.. hence I've been in a automechanic course through highschool and been maint. my car regularily...
Old 03-14-2005, 01:51 AM
Re: 01 corolla LE
Actually, I meant that once you pour some seafoam into the engine...well...you'll see what I mean.
Old 03-14-2005, 11:51 AM
speedracer41 speedracer41 is offline
Re: 01 corolla LE
Have you tried to swap the coil?
2003 Corolla S
www.ImportAtlanta.com
www.VVTI.net
